329 engine Has Diesel in oil
RAR/IA
09-25-2003 18:47:09
Actually the 329 is in a 4400 combine. Getting Diesel in the oil, about 2 gallons in less than 8 hours. Have replaced mechanical transfer pump. Engine runs great. Can the seal in the pump shaft do this? Is it possible to replace easily or does a pump shop have to do it? Thanks,
Roger
RJ-AZ
09-25-2003 21:06:31
 Re: 329 engine Has Diesel in oil in reply to RAR/IA, 09-25-2003 18:47:09
Yes the injection pump seals can leak on that engine. We have that problem in our area on cotton pickers a lot. It's best to get an engine manual for that series of engine. You can set the engine up on TDC, there is a cover and bolt on the inj pump side by the flywheel housing where you can remove the bolt and stick the long end back into the hole and dog it into TDC. The long end will slip into a hole in the flywheel at TDC #1 & #6. You can get it 180 deg. out if not careful. The inj. pump has a rectangular window with 2 screws where you can line up two marks on the pump innards. These marks and the flywheel should agree. Now on most of these you can pull the pump right off of the drive after unbolting everything. There are two cup seals facing opposite on the shaft that remains on the drive gear that you replace. Now the trick is to install the pump without rolling the seal cup that faces the pump over. Use some slickum.
jdemaris
09-26-2003 05:46:00
 Re: Re: 329 engine Has Diesel in oil in reply to RJ-AZ, 09-25-2003 21:06:31
Just adding my two-cents. When you've got the pump off, inspect the bronze bushing inside the pump where the two umbrella seals ride. It if has deep gouges in it, the bushing will need replacement along with the seals. It can be done, with the proper tools, without dissassembling the pump. A note on pump timing. I've found with many engines, considering the machine starts and runs fine now, you best scribe a line between the pump mounting flange and engine. This, so you can tell exactly what position the pump was in before removal. You might be able to tell anyway, by paint marks. I was a mechanic for a JD dealer for 30 years, and found that many engines did not run all that well if static-timed as per service manual instructions. Static timing mainly affects cold starting and idling. When RPM reaches above idle, the fuel-advance mechanism kicks in and is adjustable independent of the static timing. I've worked on engines, old and new that skipped and smoked excessively at cold start until the static timing was advanced a few degrees. So, my point is, considering the engine performs fine as is, put the pump back, as was. A note on installing the pump back over the shaft once you've replaced the seals. Borrow a little hand-held compressor from someone, installation will go much better. The two seals face opposite directions. One keeps fuel in the pump, and one keeps oil in the engine. The seal facing the pump will want to flip over, and it's hard to tell when this happens . . . until you find your crankcase filling with diesel fuel again.
RJ-Az
09-26-2003 15:58:22
 Re: Re: Re: 329 engine Has Diesel in oil in reply to jdemaris, 09-26-2003 05:46:00
You covered the rest of the fine points I left out. I've only got 12 yrs. in a JD dealer shop.
jdemaris
09-26-2003 19:17:59
 Re: Re: Re: Re: 329 engine Has Diesel in oil in reply to RJ-Az, 09-26-2003 15:58:22
If you're at the 12 year point, you're probably a better mechanic than me. I've geen getting greasy for over 40 years, and tend to get tired and bored with a lot of this stuff. I used to regard all broken machines as challenges, and therefore gave them more thought. Now, I'm only smart if I'm interested in something.
RJ-AZ
09-27-2003 10:03:44
 Re: Re: Re: Re: Re: 329 engine Has Diesel in oil in reply to jdemaris, 09-26-2003 19:17:59
I'm 54 and have 12 years in JD dealer shops but have been getting greasy since I was a kid. Never did get smart enough to get a real job! When I was 3 yrs old my dad had a town job at the grain elevator and we lived across the alley from the JD dealers lot. My mom would find me missing and come and peel me off of a tractor. I later went to work in that same shop when I got out of the army in 1971. I now work for the state highway dept. in AZ.
jdemaris
09-28-2003 07:07:20
 Re: Re: Re: Re: Re: Re: 329 engine Has Diesel in o in reply to RJ-AZ, 09-27-2003 10:03:44
This probably is the wrong forum for reminiscing, but I'll say this. I grew up in NJ, 7 miles from New York City. As a little kid I hung out at a retired mechanic's place. He built his own "victory" tractors and I was fascinated. He built most everything from cut-up Crosley cars and trucks. He did have one that had an Indian motorcycle engine in it. My hometown was relatively rural with a few little chicken and horse farms. In the early 50s building went crazy. Everything was bulldozed and new houses went up everywhere. Heck, it's still going on. Anyway, there was heavy equipment everywhere. I was hooked. We used to go to the building sites at night and start some of the stuff up. Probably came close to killing ourselve's a few times. So . . . maybe that ruined me forever. According to my ex-wife, I never had a "real" career. In fact, she left me after I took and hour off work from a John Deere dealership, and came to my kid's kindergarden graduation with greasy workboots on. She said I was a greasy slob and she could not take it anymore. During a few bad years in the late 80s, I got run over by a Massey Ferguson and broke my neck. Then, a few years later, I had to jump off a run-away John Deere 3020. Engine stalled coming down a steep hill, synchro-range jumped out of gear, no steering, no brakes, and I was flying. Jumped off and broke both legs and heels. So, now I'm a little gimped up. Went to college, got a few degrees and thought I could change my life and finally get a "real" job. Well, it never happened, I couldn't stand it. Now, I have a new wife (well, 10 years new). Around 30 tractors and crawlers, another 30 cars and trucks, small farm, and still . . . no career. I figure, it's too late now, I'm a lost cause. Good thing my wife has a real job, which too is sort of an escape. She's an assistant director of a living history museum. I'll stop, end of story.
RAR/IA
09-26-2003 18:43:21
THANKS to both of you for the help!
I had 28+ years in the hay factory so do not know a whole lot about injection pumps!
Roger
