'51 MT Touch-O-Matic Breather Cap
J.P.
01-20-2004 11:22:51
Our service manual says to wash the breather cap of the Touch-O-Matic system every 120 hours, but does not clearly show where is the breather or how it is to be removed. There is a disc shaped object about 2' in diameter with three small depressions on its surface located on the very top of the unit; this appears to be the breather, but how is it to be removed for washing? The fill cap located just to the rear of the control levers does not have any type of breather holes.
tom
01-20-2004 15:50:36
 Re: '51 MT Touch-O-Matic Breather Cap in reply to J.P., 01-20-2004 11:22:51
JP,
You proposed a very good question regarding the breather-cap. The breather cap is on top of the value housing. I tried taking my breather-cap off and the rivets started to break...i just put hammered it back down...
when i overhauled my TOM, i soaked the valve housing for 3-4 weeks in solvents, then pulled all the old [copper-wire - same wire in the top of your breather cap for your oil] out and replaced it with a copper-wire from scrub brush...you can then flush this out with solvents while you change your TOM fluids, but don't clean your breather cap, or flush it, unless you change your hydraulic [10wt] oil because debris can get in and clog a valve or something...
post back if you have any more questions...
tom
J.P.
01-20-2004 16:13:01
 Re: Re: '51 MT Touch-O-Matic Breather Cap in reply to tom, 01-20-2004 15:50:36
Thanks Tom, I think we'll just leave her alone for now; don't fix what ain't broke!
tom
01-21-2004 05:24:50
 Re: Re: Re: '51 MT Touch-O-Matic Breather Cap in reply to J.P., 01-20-2004 16:13:01
JP,
That's usually a good strategy, but regular maintenance is also important on the TOM and anything else or it "will become broke[n]"...
i suggest that if you have never changed the hydraulic fluid [10wt oil] in the last yr or so, then do so and clean the breather cap then...
try this order...clean cap, drain oil, flush one or twice, refill...good luck, tom
