Low Oil pressure
Bill G
09-25-2003 09:43:29
Got a 1010 RUS that has had a rich carb. Gas was getting dumped into the engine and thinning out the oil. I changed the oil recently (10w-40) and the pressure hasn't gone back up. Oil pressure is reading around 5-10 psi. Previously it read around 40 psi. After the tractor has warmed up a bit the pressure raises, but only to about 15-20 psi. Any ideas on what could be wrong or what I could do to raise the pressure.
On a side note: a side effect of this problem has caused the throttle to stick open. I can slow it down at the carb, but the throttle lever seems to only slow it a little bit. Too fast for idle.
Thanks, Bill
ChuckW
09-25-2003 10:15:29
 Re: Low Oil pressure in reply to Bill G, 09-25-2003 09:43:29
excessive wear in oil pump?
