JD 50 question.
Mike
09-25-2003 08:10:08
Can you mount a frontend loader (bucket)for a JD 50? If so where would you get one?
Thanks
ellis b
09-25-2003 18:36:48
 Re: JD 50 question. in reply to Mike, 09-25-2003 08:10:08
Yes, you can. I mounted a KOYKER brand on my 730, but I had to fabricate the mounting brackets. Also, I had to build a different power steering by mounting a double acting slave cylinder on the front axle and mounting an operating valve on a fabricated tie rod. It all has been working very well for about 5-6 years. I doubt if the stock power steering on you 50 will handle the extra weight. You might consider mounting an auxiallary DA cylinder on the front axle, assuming it is wide front end, and tap in the existing hydraulic lines. I don't know if I would try it if it is a tricycle front end.
Mike
09-26-2003 05:30:49
 Re: Re: JD 50 question. in reply to ellis b, 09-25-2003 18:36:48
OK, Thanks for the info.
