Hello. I am just going to throw a lot of information out in hopes that some of it connects together in some way. In short, the left cylinder seems to be running significantly stronger than the right cylinder on a 1944 B. Now the details: * The tractor has new cylinder sleeves, valves, and valve seats. The pistons are .045 oversized with new rings. The engine work was recently completed and currently has about 1 hour of light running time on it. * The tractor starts remarkably easily by hand in two turns of the flywheel. No choke is needed when hot or cold. * When the engine is up to temperature, and the left compression petcock is opened, there is a crisp snapping sound from the discharge and the engine speed increases slightly. When the right petcock is opened, the discharge sounds more like an air compressor puffing air, and there is a slight oil mist discharging as well. The engine speed increases quite noticeably when the right petcock is open. * Both spark plugs are brand new Champions. I have used two sets of brand new Champions (21 and 16) and the results are the same. Solid core wires are used. The magneto was just rebuilt professionally, and the spark looks good when hand cranking. When running, I touched a separate spark plug wire to the cap of the left cylinder spark plug and watched as the magneto lit the second spark plug up, which was grounded to the frame, with a bright blue spark. The right cylinder produced the same results. I am convinced the magneto is good. * When starting, you can position the crank to fire up using either cylinder. Both cylinders will ignite right away to start the engine. * The engine misses just a little bit at idle, but as the RPM increases, so does the frequency of the miss. * At any RPM, the right spark plug wire can be removed, and the engine RPM is unaffected. If the left spark plug wire is removed, the RPM drops drastically and the distinctive popping sound disappears. * Compression was checked while hand cranking slowly with the relief petcocks closed. Both cylinders read about 55 psi when cranked at the same speed. The flywheel is very difficult to rotate without the reliefs open, so I believe the compression is OK. * The valve pushrods were all intially set with .020" lash. * The carburetor was rebuilt by me using a kit from the dealer. The load adjustment is out about 1-1/2 turns and the idle is out about 3/4 turn. Turning either one inward to lean it out, makes the engine go faster. When turned all the way closed, the engine is still running. Although the carburetor is probably not setup exactly right, I do believe that since the left cylinder is running properly, and both cylinders use the same carburetor, that this is not the problem. * I am using 10-30 oil. * The left cylinder head, spark plug, and petcock is noticeably hotter than the equivalent pieces on the right cylinder. The left spark plug will burn your finger after running, but the right one is not very hot. * At low RPM, the tractor can go up a slight incline at slow idle in 4th gear, and do quite well. When given more throttle, and in 5th gear on the same incline, the engine will bark 3 or 4 times loudly (as it should), and then stop altogether, then bark 3 or 4 times, then stop, and continue this until the throttle is backed off. Downhill under higher throttle settings is not much better. * At first startup after the rebuild, the oil pressure was at the "M". After 5 minutes, the pressure was almost at the "L". I adjusted the oil pressure regulator in the crankcase outward 2 full turns, and now the pressure is resting in-between the "L" and the "M". This is the first time since I have owned the tractor that it has run, so I don't know what the pressure read in the past.With all that said, is anything standing out as the reason the left cylinder is so dominant? Thank you.
