Hydraulic cylinder parts
Dan
09-25-2003 07:12:10
Anyone have a good internet source for packings and seals for hydraulic cylinders? Repairing an old JD A cylinder, need the chevron packing seal and cups if possible. I know some parts are no longer available from Deere and those that are are expensive. These look fairly standard and thought I might find them at a hydraulic parts outlet.
John
09-25-2003 18:47:17
 Re: Hydraulic cylinder parts in reply to Dan, 09-25-2003 07:12:10
I guess I have about the same problem. I have one for a B that I want to repack this winter. What do they look like inside, are they hard to take apart and put back? I also need the pin (goes up and down) that holds one of the cylinder attaching pins in, does anyone know where I can get one? Thanks!!
Dan
09-25-2003 19:39:27
 Re: Re: Hydraulic cylinder parts in reply to John, 09-25-2003 18:47:17
the cylinder is easy to take apart. There are 4 bolts on the non moving area. Then you can tke the nut off the inner end of the rod and pull the rod out the other end. On the end the rod comes out there are 2 bolts that hold a piece in that pushes agains some chevron packing. On the cylinder plunger are 2 cups, one going each way. Not much to them. Found the chevron type packing. JD dealer said the number I had was not available, cups were obsolete. The had some chevron typ packings that seem to be about the right side. The cups in mine are not that bad so may be able to use them again.Think I can cut the gasgets for either end or use the old ones with soem silicone. According to the parts book for this cylinder there were several different plungers by serial number. Mine has a serial number stamped on one end. If you are around somewhere that has a hydraulic repair shop you might be able to find the cups to match up. These old tractors didn't have a lot of pressure so things don't have to be perfect. Good luck and let me know how you come out, if you have access to a B parts book it shows the breakdown on the hydraulic cylinder.
john
09-27-2003 06:43:24
 Re: Re: Re: Hydraulic cylinder parts in reply to Dan, 09-25-2003 19:39:27
Thanks Dan!!! Mine is leaking where the 4 bolts are. Maybe I can get by by just making a gasket, is it just a regular gasket or something special? It seems to extend ok (When hooked up to just the tractor)and will be used only one way. I don't have a parts book for the B. Thanks!!!
