244 corn head gathering chain
HA in Oh
09-24-2003 08:39:22
I just purchased a 300 husker w/ a 244 head and one of the gathering chains is lose. I'm not sure how to adjust them, but it looks to be out of ajustment. I don't see a master link, how do you get the chain off?
Mark
09-24-2003 15:00:43
 Re: 244 corn head gathering chain in reply to HA in Oh, 09-24-2003 08:39:22
When I worked at a dealership we used to put a half link in them, available from deere.
37D
09-24-2003 10:16:25
If it's like a 444 & I think it is, it is spring loaded. Take off the center snout, if it is one of the inner ones, & check to see if the spring loading on the lower sproket is free, these tend to get full of dirt, etc & bind up. If this is ok your chain is most likely worn out. These are "endless" & have no connector link & when worn beyond the tighteners ability to take up slack, must be replaced. The good news is, they aren't very expensive, somewhere in the low $20s each.
HA in Oh
09-24-2003 11:06:39
 Re: Re: 244 corn head gathering chain in reply to 37D, 09-24-2003 10:16:25
Thanks for the info. It is the far outside one,it was dark last night when I was monkeyin with it. I did see the spring loaded bolt, I will check that out tonight. Do I need to take off the outside snout? And if I need a new chain does it come out the top after the snout is off?
37D
09-24-2003 19:06:39
 Re: Re: Re: 244 corn head gathering chain in reply to HA in Oh , 09-24-2003 11:06:39
Yes & yes!!!
