JD 46 D knock
jcunningham
09-24-2003 03:48:26
Thanks to all on this site that helped me get my 46 D going again. I had to redo the head,carb and the magneto needed parts. The engine sounds good except I am hearing a knock not with every fire but when I load her up. The flywheel was loose and I tighted her up with the spilt bolts as tight as I could only for it to get loose and move down the splined shaft each time I run her. I did take out shims in the rods and the right cylinder rod is looser than I would like to see but one more shim binds her up. I would love to get rid of the knock.
BWINMO
09-25-2003 19:16:16
 Re: JD 46 D knock in reply to jcunningham, 09-24-2003 03:48:26
The knock could be a piston pin.
