J D D
mike
09-23-2003 17:50:15
My D was running great when i took it out to the farm for some pictures. The tractor sat out for 3 weeks , everything was covered. It is running on one cyl now! I have gas and spark in both cylinders. I believe i have a stuck intake valve.
Can i get to the valves without taking the tractor apart? I just need to give it a tap, i hope. We have had alot rain and very humid conditions all year.Three of my case tractors had stuck valves, they all had fresh heads.Any help would be great
Thanks Mike
John T
09-23-2003 20:33:45
 Re: J D D in reply to mike, 09-23-2003 17:50:15
Mike, yes, you can get to the rocker arm assembly and valve stems just by removing the valve cover. While there you can lightly tap to see if any valves are stuck and will free up and check the lash settings. Some folks have good luck running Marvel Mystery Oil in the Crankcase as a top and valve system lube and hopefully you can get it unstuck (if thats your problem) and keep her exercised and you will be fine.
Good Luck n God Bless John T in Indiana
Clooney
09-23-2003 17:55:04
Mike, just pull the front valve cover to expose the valves. [just the tin one NOT the rocker box]
~If you don't have a stuck valve then I would suspect water or moisture in the distributor cap..
mike
09-24-2003 18:00:11
 Re: Re: J D D in reply to Clooney , 09-23-2003 17:55:04
Hey , thanks for the help, took offf the rocker cover, and everything appeared to be in working order. The atf fuild i put in the cly. did the trick. The d was running on two cylinders!!
I'am getting some back fire when i bring it down to idle, and then give it some gas.What do you think i need to do to fix that problem? The tractor doesn't backfire while driving, feels like it has good power. .
Thanks
RJ-AZ
09-25-2003 18:16:55
 Re: Re: Re: J D D in reply to mike, 09-24-2003 18:00:11
I have seen problems in two old tractors here in my wide spot in the road. One was a Ford 9N the other a JD-B. Both tractors had been running and then sat for about 3-6 months. The valve stems hand taken on varnish from the fuel and when cranked over all four intakes on the 9N stuck open. The JD though would belch and backfire kinda like you said because the valve was dragging when it closed. This new gas sure seems to gum up faster for some reason.
