Welding cast wheel ears question
Bguy
01-20-2004 10:01:13
I have a round spoke wheel that has the ears on the cast hub broken. I am wanting to use the wheel on a show tractor if it can be welded up good enough for this purpose and look OK. I don't want to fool with it if I'm going to always be worrying about it breaking or if it looks bad. Does anyone have any experience they could share about this? Thanks.
Deere Heaven
01-20-2004 11:51:20
 Re: Welding cast wheel ears question in reply to Bguy, 01-20-2004 10:01:13
I have had a rear wheel with the same problem and had the ears welded on just fine. I am having two more done right now. I work at a caterpillar dealership in Austin and our welders are experienced in welding castiron. He said the have to use a special rod and heat the area up and let it cool slowly. Some times the bury it in sand to slow the process down. Brian Nielsen Austin, Tx.
Deere Heaven
01-20-2004 12:14:32
 Re: Re: Welding cast wheel ears question in reply to Deere Heaven , 01-20-2004 11:51:20
I took a spair axel shaft and they use this to align the ears. I dont think they welded the inside. The one I had done was repaired about 4yrs ago and is still fine. Try not to tighten the clamping ring to much. From what the welder is telling me that they grind most of the crack out and fill it back in with weld. Both of the ones I am having done now have been fixed like this befor, but they added studs to stengthen them. Brian
Bguy
01-20-2004 13:03:48
 Re: Re: Re: Welding cast wheel ears question in reply to Deere Heaven, 01-20-2004 12:14:32
I'll tell my welder about grinding out the crack and welding from the outside. I wish I had a spare axel shaft to work with, that would help hold everything in line.
Bguy
01-20-2004 11:57:59
Brian, Thanks for the response. The guy I use is a pretty good welder. As a matter of fact, I meet him through my Cat dealer and he's welded a lot of cast. He seems to think he can weld it up OK but he's not sure how strong it will be or how to cut the splines back open after he welds it. There's no way to get in there with any kind of cutter or tool that I have and it will take a while to do it with a file. How did you fix yours?
