1945 JD GM hand crank
Hank
09-22-2003 20:25:49
I have a 1945 JD GM hand crank, wondering if anyone knows a value and if anyone has a clue how many are in existence. Haven't seen any at any shows, etc... Thanks in advance.
Hank
09-24-2003 20:17:07
 Re: 1945 JD GM hand crank in reply to Hank, 09-22-2003 20:25:49
Thanks to all for the responses. I meant to say I haven't seen any other hand crank JD's with the modern grille... This seems to be a rare combination. Or at least I haven't seen any others. Any thoughts? Value?
Thanks again.
Mikey G
09-23-2003 16:18:11
G Man Is very correct the flywheele is worth 1200 to 1500 dollars but you need a few other parts to convert back to hand start correctly. I have no input as to how many hand start Gm are left but if its on steel it worth atleast an US G maybe 2 of them
Mikey G.
G-MAN
09-23-2003 07:45:55
There's probably no way to determine for sure how many are out there, as many that were originally hand-crank were probably converted to electric start. It is safe to say that hand-crank "GM"s are probably considerably more rare than electric-start ones, and it's probably more valuable left as-is. The flywheel alone is probably worth a good chunk of change, as there are many guys wanting to convert electric-start "GM"s back to hand-start, because of the higher value and rarity.
38 JD A
09-23-2003 06:46:06
I SAW TWO HAND CRANK GM JOHN DEERES AT THE DOVER OHIO SHOW IN AUGUST OF THIS YEAR DON'T REMEMBER WHAT YEAR THEY WERE
