4020 PTO CLUTCH AND HYDRAULICS
CARL
09-22-2003 15:38:49
I A FRIEND THAT IS HAVING SOME PROBLEMS WITH A 4020 EQUIPPED WITH A 158 LOADER. ONE PROBLEM IS THAT THE LOADER CHATTERS BADLY WHEN RAISING IT EVEN AT HIGH RPM AND DOES NOT GET WORSE IF YOU ARE STEERING AND RAISING 3 POINT AT SAME TIME. THE OTHER PROBLEM IS THAT THE PTO CLUTCH IS SLIPPING AND SOMETIMES JUST WILL NOT RUM THE 8 FOOT BRUSH HOG ON IT. I HAVE NOT DRIVEN THE TRACTOR BUT THE FLUID WAS A LITTLE LOW WHEN I WENT TO LOOK AT IT BUT WE TOPPED IT OFF AND I DID NOT OBSERVE ANY MORE THAN NORMAL HYDRAULIC LEAKAGE ON A 40 YEAR OLD TRACTOR, LOOKING FOR SOME ADVICE ON WHAT IS WRONG WITH TRACTOR, I AM NOT TO FAMILAR WITH NEW GENERATION TRACTORS MAINLY FOOL AROUND WITH OLD 2 BANGERS AND MY FRIEND HAS NOT MADE A INVESTMENT IN TECH MANUAL ON THE TRACTOR THAT I COULD GAIN SOME INSIGHT OF HIS PROBLEM
WIZ
05-07-2004 07:04:55
 Re: 4020 PTO CLUTCH AND HYDRAULICS in reply to CARL, 09-22-2003 15:38:49
I HAD THE SAME PROBLEM WITH MY PTO SLIPPING AND NOT PULLING UNDER A LOAD. THE PROBLEM TURNED OUT TO BE THAT THE PTO THROW-OUT-BEARING HAD FROZEN UP AND WHEN ENGAGED IT WOULD NOT SPIN WITH THE PTO CLUTCH. WHICH, IN TURN GRINDED THE END OF THE PTO CLUTCH FINGERS DOWN SO MUCH THAT I WAS NOT FULLY ABLE TO ENGAGE THE CLUTCH. TO INSPECT YOUR FRIENDS PULL THE ACESS COVER OFF AND SHINE A FLASH LIGHT UP INSIDE CLUTCH HOUSING. MAKE SURE TACTOR IS OFF AND IN PARK.
G-MAN
09-22-2003 15:45:25
Is the tractor a powershift or a synchro-range? That's going to be the determining factor in where you need to start looking for problems, as they operate in different manners. If it's a synchro-range, does he have his foot on the clutch while he's trying to run the loader? With the clutch down, the transmission pump is not turning, and as the tranny pump charges the main pump, the main pump may not be getting enough oil. The return oil from the opposite sides of the cylinders should also return to the pump, but if the main pump has a bunch of internal leakage, or there are other internal leaks, it may not be enough to keep the pump supplied. You really need to buy or borrow the correct tech manual to diagnose these issues, as there are many possible problems and solutions. JD service manuals generally do an excellent job of providing testing procedures, as well as explaining how the system funtions, and are well worth the investment.
carl
09-23-2003 14:43:43
 Re: Re: 4020 PTO CLUTCH AND HYDRAULICS in reply to G-MAN, 09-22-2003 15:45:25
got back with my friend that owns the tractor and it is a syncro tranny, whe we were running the tractor last week end it was in neutal so we never push on the clutch, we ran it a various rpms.
RJ-AZ
09-23-2003 09:15:48
If this is a synchro range tractor the trans pump(which also serves as a charge pump) is driven by a LONG hex shaft that engages the end of the crankshft and extends all the way to the rear of the tractor.The access plug is hidden under the top link braket. You can remove the top link bracket and access plug and pull it out. It may be rounded either at the crank end or where it passes through the pump drive.But then again if all of the rest of the hyd system is working it may just be in the loader valve.
G-MAN
09-23-2003 10:56:55
 Re: Re: Re: 4020 PTO CLUTCH AND HYDRAULICS in reply to RJ-AZ, 09-23-2003 09:15:48
Your information is incorrect. This is a 4020 we're talking about. The tranny pump on a 4020 synchro is driven off the back end of the transmission top shaft, not a long hex driveshaft. That hex driveshaft for driving the tranny pump was not introduced until the 30-series came out. If the clutch pedal on a 4020 synchro is down, the tranmission pump is NOT turning, and is NOT charging the main pump.
RJ-AZ
09-23-2003 16:43:54
 Re: Re: Re: Re: 4020 PTO CLUTCH AND HYDRAULICS in reply to G-MAN, 09-23-2003 10:56:55
My apologies!! The G-Man is right about that I was cornfused on that changeup.
