2130 overheating
Paul
09-22-2003 15:03:09
I have a 1979 2130 which has done at least 9000 hours. Just latley it has been overheating when we use a two drum mower, but it's not so bad when we use a baler! Rad was cleaned out last winter, air filter is ok, fan belt seems ok. I have tried the mower on another tractor with no trouble. please help. thank you
John
09-22-2003 16:21:41
 Re: 2130 overheating in reply to Paul, 09-22-2003 15:03:09
I`d give that radiator another cleaning as its the easiest thing to do first. Blow it forward and get close to the fins with the airgun. Dont forget to do the cooling fins on the oil cooler alongside the radiator. Should that not be productive I guess the next step would be a cooling system flush. Maybe put in a new thermostat while the systems drained down. Just a thought, are you loosing coolant? Check the engine oil for water and also your coolant for oil. That series tractor was prone to electrolysis. Beyond that I suppose
Paul
09-23-2003 13:55:53
 Re: Re: 2130 overheating in reply to John, 09-22-2003 16:21:41
Thanks John, I will clean the rad again as she is not using any water and it seems clean.
