Tyler: A couple of questions: You said: ~The block is worn in two places in each cylinder where the broken ring was running How deep is this wear? ~There is a .004 taper from back to front in the cylinders (I suppose this is normal for a wear pattern.....but he didn't indicate that the cylinders are egg shaped)
Is this total taper only, or taper from min to max? difference is that sday you had a cylinder that was worn .010" on the bore in the back and .014" in the front, you would have .004" taper. Just a comment, but if you only have .004" total taper, and the wear from the broken rings is not too deep, you MIGHT (emphasize might!) get by with a trip to the honing machine using a Sunnen type fixed diameter hone. Using coarse stones first, then finish stones, they MIGHT be able to get your bores back into cylindricity and still allow you to use your old pistons. This is speculation at this point. ~Crankshaft rod journals are worn .002 from standard. Do I need to have it turned (very little grooving)?? Couldn't I get a set of .002 or .004 undersize rod bearings from JD(still avail. from a dealer) and get by with emry cloth smoothing???? That would save several $$ Again, is the lowest spot on the crank .022" from standard, or is it worn uniformly .002" undersized? If it's just .002" under and still round, .002" U/S rod bearings will work just fine. I like to do things as right as the next guy, but remember, these engines don't turn very fast, and most machinists are looking at your engine as if it were a high reviving Chevy. You can polish those cranks very nicely, especially since you say you'll take it out anyway. ~I am also going to have my crankshaft repaired (it is worn badly where the clutch pulley bearing rides) They will turn it down a bit and weld it up and turn it down to spec again. He warned me that he couldn't guarentee the work, but said that the new material probably wouldn't be as hard as the steel in the crank. I'm not overly concerned as it should be fine as long as it it properly lubed. How badly is this area worn? Apparently the bearing has spun there for a time? Remember, this bearing only turns when the clutch is disengaged, so that land doesn't have be real pretty...your call. That's my $.02 given the information. Frank
