8440 transmission
richard tully
09-22-2003 11:46:27
help
i am looking for an 8440 for use in forestry work ,i looked at one today but the gearbox (quad range)the a b c work ok but d you cant get i asked they said it isnt there on artic models is this true ?
please help
G-MAN
09-22-2003 17:19:52
 Re: 8440 transmission in reply to richard tully, 09-22-2003 11:46:27
I'm not a Deere 4wd expert, other than spending a bunch of time in an 8450 and working on a few, but I've never heard of an "arctic" version of any John Deere 4wd. That's not to say that they don't exist, however. I tend to agree with John that they're pulling your chain, and that if it has a normal quad-range shifter, it should have D-range. However, the problem could be as simple as a linkage adjustment or shifter problem, or as complex as major internal tranmission damage. I'd take along someone knowledgeable to look at the tractor, as if it's a relatively simple fix, that could be a good bargaining chip. But, keep in mind that if they'd lie about that (and maybe the guy just doesn't know beans), they'll probably lie about anything else or other problems. On the whole, probably a good one to stay away from. I will say that the 8430. 8440 and 8450 are probably the best of those series of tractors, as the 466 engine is more reliable than the 500-series engines used in the bigger models, and the rest of the tractor holds up well at those lower horsepower levels.
John Jenkins
09-23-2003 07:38:24
 Re: Re: 8440 transmission in reply to G-MAN, 09-22-2003 17:19:52
I assumed by �artic� he meant articulated but you know what happens when we assume things.
G-MAN
09-23-2003 07:51:10
 Re: Re: Re: 8440 transmission in reply to John Jenkins, 09-23-2003 07:38:24
Well, I guess I've never seen a JD 8440 that wasn't articulated. My take was that they were trying to sell him a bill of goods, particularly when he's interested in it for logging. That's what clued me in that he was probably up north somewhere.
John Jenkins
09-23-2003 08:47:11
 Re: Re: Re: Re: 8440 transmission in reply to G-MAN, 09-23-2003 07:51:10
My take was that they were trying to tell him that articulated Quad-Range tractors only had three ranges as opposed to Row-Crop Quad-Range tractors like 44-
4640s, etc. The use of artic instead of arctic made me think he meant articulated. Maybe it�s like you thought and they really don�t know much about the tractor but either way, I�d rather buy one from someone who knew the machine well unless the price was just unbelievably low. I smell a rat on this one.
G-MAN
09-23-2003 11:01:33
 Re: Re: Re: Re: Re: 8440 transmission in reply to John Jenkins, 09-23-2003 08:47:11
Now I understand what you're saying. It's pretty much like we said, if the slot is there, the gear should be there. I know for a fact that the 4WD quad-range tractors have "D" range, because I've ran and worked on a few. I'd say it's pretty apparent that at any rate, they don't know what they're talking about. And you're probably right about the "artic" meaning articulated. I guess I never thought of that meaning, because I know that it SHOULD have "D" range.
richard
09-24-2003 10:04:36
 Re: Re: Re: Re: Re: Re: 8440 transmission in reply to G-MAN, 09-23-2003 11:01:33
thanks for your answers it has confirmed my suspicions .i am sorry i caused you confusion with artic (aticulated )it will be used in england ~(uk) there are not many over hear at all but a nice looking tractor it has had an engine block in it ,new crank pistons and all its at its original hp and not been messed with ,the gear problem does not worry me it seems very fast in c range ,all other gears select ok ,i was hoping for a powershift type box .when did they fit them into artiulated tractors ?would like to know more about them if poss WWW.ATLAS-EXCAVATOR.COM
RICHARD TULLY
John Jenkins
09-23-2003 14:24:35
Right on G-Man. I sure do miss our 8630. That was one pullin� S.O.B. It couldn�t out pull our Steiger but nothing around here could back in the day.
John Jenkins
09-22-2003 13:15:30
They aren�t shooting straight with you. The Quad-
Range in those tractors does have D or else it wouldn�t be called Quad-Range. I have run 8630s and 8640s and every one of them had A,B,C and D. The 30 series shifted with separate levers for ranges and gears while the 40 series used a single lever to select range as well as gear. My advise....keep looking. Those people are lying about the transmission so who knows what else is wrong with the tractor.
