8W mower PTO shaft
Brian
09-22-2003 07:19:08
Tried to hook up my 8W mower to my B everything went smooth but the PTO is too long, It would half to be 4 inches shorter just to hook it up. Is mine possibly for a later model tractor? I need a manual purty quick. Thanks
Ray Phelps
06-17-2004 18:57:00
 Re: 8W mower PTO shaft in reply to Brian, 09-22-2003 07:19:08
How do I put on a PTO SHAFT ( JOHN DEERE TRACTOR)??
Dan
09-22-2003 20:26:37
I have an 8 W, use it on 3 differnet tractors and have 2 different length pto shafts, the male end. When I use it on my MT or IH Super MTA I use the longer shaft, on the 430 I use the short one. I leave the female end as is and make sure there is enough of the male end inside it so it won't come out if you drop the tractor front or morwer rear wheel into a hole.
RK
09-23-2003 06:16:14
 Re: Re: 8W mower PTO shaft in reply to Dan, 09-22-2003 20:26:37
Dan, would you have a picture of your No. 8 hooked to your MT?
MIKE HANLEY
09-22-2003 18:40:14
Could be that at one time the mower was on a FORD 8N, NAA, 600 or 800 tractor. The PTO on those tractors are a lot further ahead on the tractors rear end. If you cut the shaft cut off both the male and female parts of the shafts. When layed side by side the two parts of the shafts should be the same lenght. With the tractor and mower on the dead level and the PTO hooked up the male shaft should be 1/2 way into the female shaft. That gives you sliding room when going up and down hills.
Brian
09-23-2003 01:53:30
 Re: Re: 8W mower PTO shaft in reply to MIKE HANLEY, 09-22-2003 18:40:14
Thanks, I had never thought of it being used with another colored tractor, makes me feel better cutting a shaft off. Thanks for considering my question. Brian
