Clooney, Thanks for the response. First, since I'm no smarter than the parts manual I'm reading, I break the bearing into 3 components, the cup, the bearing, and the cone.I didn't intend to build up the bore of the governor housing, I intended to build up the "cup" and grind it down until I achieved the appropriate fit. Do you think this will work ? I'm worried about the bronze being strong enough. I'm having trouble understanding your other option. It sounds like the "reclaiming the governor case" procedure outlined in the Model "B" service manual except they don't cut the cone, they cut the spring and magneto drive flange by 19/32 inch each and just push on an additional cone. This in effect changes the location of the right hand bearing by 1/2 inch to the right. I'm just not convinced the amount of wear that I have warrants this drastic of a measure and besides, it can always be performed in the future. Thanks for your thoughts. You contribution to this forumn is invaluable. Mike W.
