Clutch Problems
Wayne
09-22-2003 06:04:39
I have a 1955 JD60 that all of a sudden the clutch started making quite a racket like metal on metal when disengaged and keeps jumping into engaged without moving the clutch lever. It keeps getting worse to the point you can't stop the tractor at all without shutting it off. It seems to work fine when moving, the clutch snaps in, doesn,t slip works fine until you pull the lever back and doesn't stop. I have an IT manual and was going to attempt to pull it apart myself and was looking for some advice on what I should be looking for.
Thanks
Wayne
Clooney
09-22-2003 06:53:40
 Re: Clutch Problems in reply to Wayne, 09-22-2003 06:04:39
Wayne, there are a few different things that could have happened. Your best approach is to remove the clutch cover & take a look. Look for a broken adjuster bolt, a broken or piggyback clutch disk, a broken or loose clutch driver disk, or something floating around in the clutch that's jamming the clutch up.
~My guess is you will either find a broken adjuster bolt or broken & piggybacked clutch disk..
