JD 300B Swing Cylinder Play
Eric
09-21-2003 21:58:31
Hello,
I've noticed a great deal of play in my backhoe arm lately when moving it side to side. It is a Deere 300B Loader/Backhoe. I'm looking for info on what the proper fix for this problem is. Will a cylinder rebuild kit take care of the problem or are these situations more of a control valve issue? Any help is appreciated. Thank you.
Eric.
jdemaris
09-22-2003 05:44:11
 Re: JD 300B Swing Cylinder Play in reply to Eric, 09-21-2003 21:58:31
Push the boom back and forth and observe where the slop is. Doesn't the 300 use a single cylinder swing setup? If so, it's got a bunch of linkage that gets worn out or broken.
John
09-22-2003 20:03:06
 Re: Re: JD 300B Swing Cylinder Play in reply to jdemaris, 09-22-2003 05:44:11
Yes, it has the single cylinder. It does have several pivot points on the linkages. We were wondering if there is a chance the hydraulics could be permitting the "bounce" rather than the mechanical linkages. I will specifically look for movement in the mechanical parts, though. Thanks for the suggestion.
