JD 2840
wolfy
01-20-2004 06:51:39
How does a 2840 rate? Are 2840's tough enough in rear end for 80 hp 329 cu in 6-cyl? How's their track record? Thanks.
Greasy hands
01-23-2004 21:36:36
 Re: JD 2840 in reply to wolfy, 01-20-2004 06:51:39
The 2840 model was ended early and replaced with the 2940. They must have had problems with it.
cannonball
01-23-2004 05:56:41
have 2840 here have hear more horror stories on these tractors ..but this one has been worked everyway in the world and is still going..has about 8000 hours on it..had a hyd problem ..in 8 hours was going again..line inside broke..cost less than 75 for parts to get going again..the 77 early 78 hilo had some problems that when they went out they would cost an arm and leg to repair..ours is a 1979..has been a good tractor and yes tractor can handle 329 engine..have nice day may god bless
del
01-21-2004 07:26:28
JD 2840 was not one of JD's better ideas. The 2940 was better, the 2950 better yet and the 2955 was the best. I had a 2840 and liked it real well until hydralic problems started.I spent about $4000 on it and it still wasn't right. I traded it with a little boot for a 4320. I just like the 20's. I have had 4020's and now a 4320. If I ever trade again I'll probably look at the 50 or 55 series!!
Mike M
01-20-2004 10:50:38
First let me say I have very limited experience on a 2840 but working on 1 for a local farmer does give one some experience. I have had this tractor apart from one end to the other this was no fault of the tractor but the operator.Not changing antifreeze causing liner pitting and trying to pull start a hi-lo both no no's on any model. I have always liked the 6cyl engine over the 4cyl.they run smooth and quiet no ruff or noisy idle. I also think that they are easier to work on than the smaller tractors as they have more room to work, parts are not packed in as tight.If you can live with a tractor of that larger size and don't need more than 80hp they should make a good unit that should sell for less money than a 4020.
Greasy hands
01-23-2004 21:39:48
 Re: Re: JD 2840 in reply to Mike M, 01-20-2004 10:50:38
The 2840 model was ended early and replaced with the 2940. They must have had problems.
