1944 John Deere B need more horse power
Wayne Johnson
09-21-2003 16:21:46
I have a blow-by problem. Compression is 45psi. I would like to get all I can when I rebuild it so I was wondering. Should I go for standard rebuild, or bore block up to 4.69in, from 5.50in. This would get me from an early styled B 175 cubic in. to 190 cubic in. I need all the help I can get, Thanks Wayne
mike
09-21-2003 19:05:22
 Re: 1944 John Deere B need more horse power in reply to Wayne Johnson, 09-21-2003 16:21:46
I would use JD 50 pistons, and use high altitude if you can find them, but at least use aluminum, and only go .045 or .090 over, .125 won't get you that much more and you will have one more go on bore using .090 or less on a rebore kit, plus if you go more, your into some expensive pistons and after all it doesn't sound like you want to put a stroker crank and spend alot of money, so just do it that way and take some of the head, .045 to .080 would help, don't go more if you plan to hand start it alot, if not worried about the starting, go about .125 to .150. And have a good valve job on it, use a good cold manifold , good luck.
Wayne Johnson
09-24-2003 15:02:39
 Re: Re: 1944 John Deere B need more horse power in reply to mike, 09-21-2003 19:05:22
Mike, Thanks for the reply. Could you tell me more like, why JD 50 pistons over late styled B. Just how much do I need to bore the block, and how much HP are we gaining. I only pull dead weight and weight in at 3600. Thanks so much, Wayne
