620 dash wiring
Mike F
09-20-2003 21:33:13
Can any body tell me what ultimately powers up the dash on my 620, and could I wire it up like a 60 if I use a coil with internal resistor, I have heard that the wire from the starter switch was used to boost the coil for better starting, but if all the ignition stuff is new, it should always start good, any thoughts, I don't have a resistor handy and although cheap, I have this new coil to use as the old one was leaking the oil out of it, thanks
Clooney
09-22-2003 04:03:22
 Re: 620 dash wiring in reply to Mike F, 09-20-2003 21:33:13
Mike, you ask..."Can any body tell me what ultimately powers up the dash on my 620".....Mike, to answer your question, with the engine not running the battery does�With the engine running & the generator charging the generator does.. In either case the power gets to the dash at the ammeter. The power for all the ignition, dash, & lights is picked up at the NON BATTERY side of the ammeter on that 620�
~If you want you can easily wire that 620 like a 60 & use an internally resisted 12 volt coil.. I don�t how much of the original wiring is still there but if the original wiring is still intact be sure to remove the coil shorting wire going from the coil side of the ballast resistor to the ign switch�s [mag] terminal. If that wire is still there & the by-pass wire is still intact from the starter�s by-pass switch to the coil circuit you risk a direct short if the engine is cranked with the ign switch turned off.
~I would suggest you not wire it exactly like the 60 but instead power the ign switches [BAT] terminal from the ammeters NON-BATTERY side post. Then run the ign switches [IGN] terminal wire to the coil�s power terminal {original Deere coil would be the [-] coil terminal} & aftermarket [auto parts] coil would be the [+] terminal. While in there disconnect the [MAG] terminal on the ign switch [see above]..
~If you are using a high CCA 12 volt battery you won�t have any starting problems using the 60 type internally resisted coil & eliminating the by-pass starting. If you are using old, or low CCA batteries, or thin auto type battery cables you might miss that by-pass starting in extremely cold weather�.
~Be careful with that oil leaking from the old coil,,,That oil probably contains PCB's...
[email protected]
Mike f
09-22-2003 13:49:33
 Re: Re: 620 dash wiring in reply to Clooney , 09-22-2003 04:03:22
I plan to do it just the way you stated, we are doing this all from scratch, as no prior wiring is there, thanks to all for their help.
Clooney
09-23-2003 03:50:32
 Re: Re: Re: 620 dash wiring in reply to Mike f, 09-22-2003 13:49:33
Mike, what I posted above will work just fine.. If you need any wire diagrams of either the 60 or 620 just give me a holler..
John T
09-22-2003 19:20:03
Mike, Youre sure welcome, glad we could help. John T
John T
09-21-2003 07:40:36
Mike, the power source for ignition and lights (switch) etc. should be the load (non battery) side of the ammeter. Its the same side that has a wire down to the BAT terminal on the Voltage Regulator also. The ammeter's other battery supply side is connected to the ungrounded battery post somewhere, maybe off the starter post or even direct to the battery would work.
If it was originally equipped with a 6 volt coil, a ballast resistor, and the auxiliray start wire up from the starter switch and you wish to eliminate all that and just use a 12 volt internally ballasted coil, just use the wire (or the switch IGN terminal) from the ignition switch (hot when Ignition is ON) to the new coils high (not to distributor) side as the switched voltage feed. Other side of coil is wired to the distributor.
NOTE to do that, the new coil has to be a 12 volt internally ballasted unit, cuz if its a 6 volt coil and you dont use any added external ballast, the points will draw excess current and burn up prematurely, plus the coil will draw excess current and overheat. If your new coil is a 6 volt, you need to add an external ceramic ballast resistor in series between the ignition switches output and the coils high (not to distributor) side. If you do that however and you have the start switch with the lil auxiliary side terminal, you might as well use that as a wire up from it to the coils high (or ballast low side to coil, same point) side will increase spark energy while cranking as intended.
Some 12 volt internally ballasted coils have around 2.5 to 3 ohms primary (lil + and - terminals) while some 6 volt coils may have only 1.5 to 2 or so ohms dependign on the coil make and type etc.
One reason why a 6 volt coil and an external ballast was used with the ballast by pass wire up from the start switch was to aid in cold weather starting and ONLY when cranking the coil saw battery voltage (not voltage reduced via a ballast) but then it dropped back to around 6 or a lil more so the points dont burn up too quick and the coil draws its designed for intended current.
Post back or e mail me [email protected] with any more questions.
Good Luck n God Bless
John T Nordhoff in Indiana
