Electric start for 70 Diesel
Buddy Woodson
09-20-2003 18:39:48
Does anybody out there in tractor land know for sure if a starter and bracket from a 730 or 720 will fit a 70 diesel and replace the pony motor. Are the flywheel teeth the same for electric as pony? Please help. Thanks
MIKE HANLEY
09-21-2003 07:37:59
 Re: Electric start for 70 Diesel in reply to Buddy Woodson, 09-20-2003 18:39:48
I'd have thought you would have an answer by now. I don;t have a 70 parts book, but the 720D 730D ring gear ia part #A2238R, weather elec or pony. If the 70D is a differant part number, then I don't know about a stock 720D 730D starter fitting. A good factory rebuilding place could always match a bendix to the 70D ring gear if it is differant then the 720D 730D. Anything is possible with some thought and some math. We have both our 730D's converted from 24 volt to 12 volt NEG ground. Had the work done at a factory rebuilding place (not a repair shop) at Friedship Wisc.
F-I-T
09-21-2003 09:30:25
 Re: Re: Electric start for 70 Diesel in reply to MIKE HANLEY, 09-21-2003 07:37:59
A: The 70D uses the same A 2238R ring gear. B: The 70D pony uses the same starter pinion that the 720/730 uses. C: The pony block and mounting geometry on the 70D is the same as the 720/730D's.
A=B=C....the starter and bracket from a 720/730 should fit on a 70D. Don't forget to install a crancase breather from a -20 or -30. The diesels vent through the pony, and with it gone, you'll need a vent that will prevent dirt and water from rolling in.
Frank
