1020 power steering problem again
rem0h
09-20-2003 15:45:39
earlier i posted a message that i think needs clarification
i have a jd 1020 - the kind with a seperate ps pump on the front of the engine. it has gotten very difficult to steer. when this happened a couple of weeks ago i tightened the adjuster nut on the power steering valve underneeth the steering wheel a little bit and it worked for a while. i think there may be a problem with the power steering valve assy. when i turn the wheel it moves up for 1/4 turn (1/2 till i tightened the adjuster nut) before it starts moving the steering linkage. what does it take to get one of these rebuilt? are there remanufactured parts available? what is the approximate cost? any other areas i should be looking at? i have replaced the oil, filter, and cleaned the pickup screen. any help is appreciated
Matthew
09-20-2003 19:33:18
 Re: 1020 power steering problem again in reply to rem0h, 09-20-2003 15:45:39
I had the same problem - tie rods were the answer - ball joints are completely worn. I still have not replaced them, so I have to out guess my turns before I make them.
BTW, my 1020 diesel is one of the best tractors I have ever had or operated in the last 30 years. I only wish I had a loader.
Good luck.
