..when there's a will, there's a way!
JD Guy in NE.
09-20-2003 07:41:17
..the last 2 issues of Green magazine have revealed man's abiliity to use new parts/equipment to solve old problems. In the Aug. issues 'Tip of the Month', David Owings of Eldora, Ia. and some friends of his found out that they could replace their old cranking starter on their 1940 A (it had been converted from a hand start) with a starter from a series 8000 JD. After analyzing the gear reduction and voltage/amps required to crank the old 2-cylinder it was determined that only some minor modifications were required to make this not only work, but work better than the original! They also determined that after it was installed without any major modifications that this setup would work on any JD 2-cyl., A thru G! (the H was untested) Now those cold weather starts for the old A are hassle free!
The Sept. issues 'Tip of the Month' posed another problem, what can you use to replace the pony motor to crank start a diesel? Donald Ens from Stanley, N.Y. came up with an idea to replace the pony motor with a 10hp single cylinder Tecumseh engine and made it work on not one, but two 70 diesels! Not only will it start both diesels with ease, he can start his 70's with the transmission engaged. He has also used the Tecumseh 'pony' to move his tractors in tight spots in the shed and actually used it to drive his tractor home when a fuel line broke in the field! Both these articles are excellent examples of how old problems can be solved using parts or equipment that is available today when people think these problems out and follow thru and overcome the obstacles they encounter along the way. If your a JD problem solver both these articles should be read to see how you can make your ideas work!
Dan
09-21-2003 10:37:22
 Re: ..when there's a will, there's a way! in reply to JD Guy in NE., 09-20-2003 07:41:17
I think it is interesting to see some innovations at tractor shows. How some folks in the past solved problems. Many are very well done and while not original definitely added to the usability of the tractor. Others are cobbled and either had little thought behind them or the inventor did not have the knowledge or tools needed. There is a JD B with loader at a local show that was adapted for live hydraulics by putting a spocket on the flywheel that drives a hydraulic pump. Makes it tougher to start(hadn start) but serves the purpose and since it bolts to flywheel could be removed if desired. My tractors are users, not showers. I don't care if they have the out of the factory options, I adapt thema s I need to especially when parts are not available. I try to not permanently disfigure the equipment though. Several years ago in Green Magazine there was a JD A with a chevy V8 engine. Looked really good, not something I would do but looks good. My point is there are 2 groups of folks, the ones that want everything like the day it came out of the factory for shows and those of us who use the stuff everyday and need it to work right for us. Just different ways of meeting a need.
steve II JD4000
09-20-2003 20:07:53
HI how far are you from Omaha??
I am moving to Omaha. I am sure could use some new buddys around.
Oh, joy.............
09-20-2003 18:01:18
Yep, never ceases to amaze me, the ways people find to screw up John Deere tractors!!!
JD Guy in NE.
09-20-2003 18:30:09
 Re: Re: ..when there's a will, there's a way! in reply to Oh, joy............., 09-20-2003 18:01:18
obviously you haven't read the articles or you wouldn't have made that statement and Green Magazine wouldn't have featured those articles. Guys like you still believe that if it isn't from JD, it can't be any good. Well, what will they be doing 100 years from now to keep these tractor running?? Read the articles first and then decide if these weren't good conversions/substitutes.. better to keep 'em running then to leave them sit and rust!
CJDave
09-21-2003 19:13:03
 Re: Re: Re: ..when there's a will, there's a way! in reply to JD Guy in NE., 09-20-2003 18:30:09
And how about the one that used a one-cylinder engine with a rubber tire drive to rotate the flywheel on the hand-crank John Deere? It always seemed to me that cranking the tractor was easier than rope starting the Briggs and Stratton and going to all that trouble, but then again, our mags were always in good shape. Then there was the one where they used the old reel-type lawnmower sitting on the ground and a long vee-belt to rotate the generator on the Farmall to "warm up" the battery so it could crank the engine. Having grown up with mostly Cats and starting engines, I have no time for any starting engine that isn't in good enough shape to start easily and run strong. Life is just too short. I don't blame the guy for substituting the 10 HP. Heck, he probly has five or six non-JD lockwashers on that tractor too if you look close.
