1020 power steering problem
rem0h
09-20-2003 06:00:48
i have a jd 1020 - the kind with a seperate ps pump on the front of the engine. it has gotten very difficult to steer. when this happened a couple of weeks ago i tightened the adjuster nut a little bit and it worked for a while. i think there may be a problem with the steering sector. when i turn the wheel it moves up for 1/4 turn (1/2 till i tightened the adjuster nut) before it starts moving the steering linkage. what does it take to get one of these rebuilt? are there remanufactured parts available? what is the approximate cost? any other areas i should be looking at?
harold bankston
10-20-2003 19:42:35
 Re: 1020 power steering problem in reply to rem0h, 09-20-2003 06:00:48
has any one heard of a kit to replace the power steering pump on the 1020 mine has went out and can't be rebuilt the new one is $1400 i was wondering is there any thing else that can be done to fix the steering
Steve - IN
09-20-2003 12:54:32
rem0h,
I had a power steering pump problem with my 1020 a few years ago. Turned out to be leaking from the seal to the timing gears. If that is your problem, you'd see bunches of fluid (like a few gallons worth) in the crankcase. A new seal is around 7 bucks from JD.
They're proud of those pumps: somewhere around 1000 bucks sticks in my memory for a new one, 700 for a rebuilt. They're three slabs of metal, a shaft, a rotor, a timing gear, a rear seal and that's it.
The only adjustment I remember (been a few years since I've been in to it) is on the front pump, not the power steering pump.
Other things to look for -- the 1020 doesn't like generic hydraulic fluid, nor two types or brands of fluid mixed together. The JD fluid is best, but found some Pennzoil fluid at about half that price that works well. Takes about 8 gallons of the stuff. Also, the sidewayes inlet screen at the bottom right rear - just behind and above the filter - can get filled with junk and starve the rear pump. If it doesn't pass fluid forward to the two front pumps, nothing much happens.
Assume you've checked for the obvious leaks, low fluid, etc. The system is self bleeding, but foaming fluid (caused by mixing fluid or bad fluid) can put it on the sidelines fairly quickly.
