1936 J.D. B MAG
Tim
01-20-2004 05:26:37
What is the correct mag for a 1936 B Thanks
Duane Larson
01-20-2004 06:35:23
 Re: 1936 J.D. B MAG in reply to Tim, 01-20-2004 05:26:37
Tim,
Your '36B B should fall somewhere in here:
1000-14037 FM DRV2B AB210R (JD p/n)
14038-24049 FM DRV2B AB706R
24050-24499 Wico AP477B AB757R
24500-37037 FM DRV2B AB706R
Note: there are some differences between the first 2 DRV2B's, as well as the flywheel. If you have an early '36 (12012-14037), post back and we'll go from there. FM is Fairbanks Morse.
Tim
01-20-2004 09:47:40
 Re: Re: 1936 J.D. B MAG in reply to Duane Larson, 01-20-2004 06:35:23
Thanks guys!!!!! !
Bguy
01-20-2004 07:23:45
Duane, Wonder why they went from the FM DRV2B to the Wico AP and then back to the FM DRV2B? Was there a supply problem? A reliablity problem?
Duane Larson
01-20-2004 08:12:12
 Re: Re: Re: 1936 J.D. B MAG in reply to Bguy, 01-20-2004 07:23:45
Bguy,
Testing the waters, I suspect. I have exchange letters between JD and FM, and JD was not happy with the quality/repair time of service by FM on mags sent to them. So this is an expected result, on the way to exclusive use of Wico's.
Bguy
01-20-2004 08:25:18
 Re: Re: Re: Re: 1936 J.D. B MAG in reply to Duane Larson, 01-20-2004 08:12:12
Duane, I have always heard that the FM mags were discontinued due to being unreliable but I have never really heard what kind of problems they had. Do you think that the service issue was a major factor behind changing over to Wico or was it that Wico had a better Mag? Or price?
Duane Larson
01-20-2004 15:24:29
 Re: Re: Re: Re: Re: 1936 J.D. B MAG in reply to Bguy, 01-20-2004 08:25:18
Bguy,
Probably a combination of everything. The RV series of magneto's (introduced in 1933) was relatively expensive with all the aluminum castings, ball bearings, brush HV takeoff, etc. inside. I'm not sure unreliability was an issue. But Wico had started putting out a cheaper line of jump-spark magneto's in the mid-'30's and I suspect that, coupled with the service problems JD perceived with FM, led to the move to Wico. JD dealers did not typically service magnetos, they were sent to the manufacturer for service (some branch houses could do the work, but that was mostly later). The service work from FM was found to be costly and poorly done by JD, and that was the service problem.
Fairbanks also introduced their FMJ series of magnetos about 1938, which were good mags, but by then I guess JD was happy with the Wico C, as indicated in several Branch House service bulletins.
