How to clean radiator fins?
Dennis
09-19-2003 16:45:11
The radiator on my JD Model 50 has about 20% of the spaces between the radiator fins (on the forward side, nothing on the fan side)clogged with hardened material (maybe Dakota dust). In the bottom 10 rows, or so, the material is moist (kind of like a sludge). Is there a best/preferred way to remove this material? Looking forward to words of wisdom.
Thanks,
Dennis
Ralph
09-21-2003 11:54:42
 Re: How to clean radiator fins? in reply to Dennis, 09-19-2003 16:45:11
If it appears wet, it may be a leak. The pressure washer isn't going to make it better, but you might as well find out if it is a leak. Could be oil or grease from the (power?) steering.
Jd jack
09-19-2003 22:59:54
I would use a pressure washer. just be careful not to bend the fins.
