Is a 1010 a Positive or a Negative Ground? Please
Josh
09-19-2003 15:51:07
I bought a 1010 JD a few months ago. The battery wont keep a charge. When I was taking the battery out of the tractor I noticed that the ground cable on the battery was connected to the (-) post on the battery. I thought that 1010's had a positive ground but I am not for sure? Also any ideas on the charging? The amp. gauge never moves? How can I check to see if the generator is charging?
Thanks guys.
Loren
09-19-2003 18:54:27
 Re: Is a 1010 a Positive or a Negative Ground? Ple in reply to Josh, 09-19-2003 15:51:07
If the amp gauge never moves I would say you have a problem. Your question above about polarizing it is a legitimate possibility or you could just need a voltage regulator. Likely you could fool with the regulator and make it work if you knew what you were doing but unless you do you should probably just spring for a new one. Take the generator and the voltage regulator off and carry them in to an automotive electric shop and they can test both for you.
P.S. Ground is negative o
09-19-2003 18:59:40
 Re: Re: Is a 1010 a Positive or a Negative Ground? in reply to Loren, 09-19-2003 18:54:27
Sorry I forgot to add that on my last post.
Negetive ground? James
09-20-2003 06:40:47
 Re: Re: Re: Is a 1010 a Positive or a Negative Gro in reply to P.S. Ground is negative o, 09-19-2003 18:59:40
I have read alot of post on here that say a 1010 JD has a positive ground system?
lloyd
10-13-2003 15:38:09
 Re: Re: Re: Re: Is a 1010 a Positive or a Negative in reply to Negetive ground? James, 09-20-2003 06:40:47
Operators manual from J.D. says positive ground.
