JD 40 Touch-o-Matic hydraulic question
DaveM.
01-20-2004 01:31:06
Hello,
I have a 1955 JD40 that I am getting ready to try to install a Horn loader on. Is there anywhere on the dual touch-o-matic to tap into to supply the hydraulic pressure to the control valve or am I going to have to tap into the pressure line feeding the unit from the pump?
Any suggestions would be appreciated.
Dave
Henry J
01-20-2004 09:53:28
 Re: JD 40 Touch-o-Matic hydraulic question in reply to DaveM., 01-20-2004 01:31:06
Dave
Dan is right. I think that by tappingg in he means that the pressure line has to be rerouted from where it comes out behind your dash through the valves/valve in the loader and then back to the pressure inlet to the tom. You have to use an open center valve and if you don't put another pressure relief (usually on the valve) you run the risk of overtaxing the system since the current pressure relief is in the tom and won't do your system any good at the loader.
Of you just try to T into the pressure line you won't get any pressure until the tom lever is activated which causes pressure to build in the pressure line - otherwise the oil is flowing continuously thru the bypass valve/valves in the tom.
Dan
01-20-2004 06:56:34
Assumig you have separate a separate valve, valves, on the loader, you cantap into the pressure line from the hydraulic pump. Run the pressure line into the input of your valve and a line from the outlet to the rear touchomatic valve housing. You might want to put quick couplers in his line so you can take the loader off. If you work it right with your connections you can remove the loader and recouple the pressure line so your touchomatic will work with loader off.
