JD 1940 H rod piston question, need help please
Denny Foster
09-18-2003 18:33:29
working on a 40 H and have a question concerning the rods and pistons, the rod bolts are not really press fit into the rods and while sizing rods on the bench I turned them the same direction for ease of removal and reinstallation during the sizing procedure, however the rods appear to have a boss on them up near the wrist pin and I am not sure which way to reinstall them onto the pistons. Bosses facing each other? both facing out?? The service book I have does not make mention of this and I am certian that there is a right way, otherwise they would not have been made this way. Also the boss is on the same side of the rod as the JD part number. Any help would be appreciated.
Denny
Donny-B
09-19-2003 15:43:49
 Re: JD 1940 H rod piston question, need help pl in reply to Denny Foster, 09-18-2003 18:33:29
Denny, My H rods have a #1 & #2 stamped on the rod body and cap machined surfaces ajacent to one rod bolt. This is to orient the cap and also should be facing upwards for installation. Hope this helps.
