530 not runing well
rem0h
09-18-2003 15:29:36
We have a 530 that does not run right. It has new gaskets on the intake and exhaust, the carb has been redone by jd, new plugs, wires, points, rotor and cap. It starts up ok but it surges and splutters as it accelerates when you open up the throttle. Does anyone know how to time one of these things? Cold compression is 85psi in each side - is this good enough? Other postings on this site say 145psi warmed up is the spec. Any ideas?
Clooney
09-18-2003 17:28:14
 Re: 530 not runing well in reply to rem0h, 09-18-2003 15:29:36
rem0h, if it's a gasoline model 530 that's mighty low on compression [should be 145 psi]. If it's an all-fuel [that's a rare 530], 85 psi is just about perfect.
~On the sputtering?...try opening the load adjusting needle about another turn or two & see what happens...that is the needle in the center of the bowl nut. If that doesn't help try running with the choke partially back on, if that helps you probably still have a carb problem. Look at the manifold heat valve to BE SURE it is either at [EXACTLY] HOT or COLD & not in between..
~On the timing, remove the little timing hole cover on the flywheel cover, then hook a timing light to the L/H spark plug & battery, then run the tractor at fast idle & point the light into the timing hole..You need it to be at the 20� BTDC mark..If it isn't, loosen the distributor & turn it until it is.....
[email protected]
