630 1st. reduction gears
Rick
09-18-2003 15:19:57
My 630 has a noise coming from I believe the 1st. reduction gear area. I had it in a shop and found the imput shaft bearings had too much play, this was repaired. The shop also replaced the 4-6 gear as the inside splines on the gear were bad. Upon inspection everything else looked ok. I have been watching these posts and noted Mr. Clooney had recomended trying gl 140. I thought I would put 140 gl in the reduction gear crank case to see if this helps the noise. Can I just change the fluid in the reduction gear area to see if this helps ? or do I also need to change the transmission fluid ? are these 2 reservoirs seperate ?
Thanks in advance for your help. Rick
Clooney
09-18-2003 15:28:18
 Re: 630 1st. reduction gears in reply to Rick, 09-18-2003 15:19:57
Rick, you can just change the gear oil in the 1st reduction cover for a QUICK test... The trans & 1st reduction cover are connected but not directly so the 140 weight will stay in the 1st reduction cover for a very short run then it will mix with the trans oil flowing in from the trans....
~You might want to just give your reduction gears more time to wear in. Anytime you disturb a set of worn in gears [especially straight cut] they will probably make some noise until they wear into their new contact pattern...
Rick
09-18-2003 15:39:42
 Re: Re: 630 1st. reduction gears in reply to Clooney , 09-18-2003 15:28:18
Mr. Clooney,
Thanks very much for your help! I will give it some time to wear in, my guy at the shop did say the new gear would take awile to wear in also. I did want to add I ck. this board every day and have learned alot from all of the information yourself and the other gentlemen provide.
Rick
