3020 drawbar/3 point arms support
Rich
09-18-2003 13:31:14
I have an oil leak in the seals around the drawbar support on my 3020. How does the shaft that holds it on come out? I'm afraid to pound on it since I'm not sure how it's put together. I loosened the bolts that hold the dust caps on and am looking at the shaft that has a half-moon shape on the ends. Is there anything else I need to do?
RJ-AZ
09-20-2003 06:42:09
 Re: 3020 drawbar/3 point arms support in reply to Rich, 09-18-2003 13:31:14
It's a simple job with couple of tricks. Support the saddle with a jack. Then use a good drift to knock the load control shaft through the first side then pull it out the rest of the way. Drop the saddle so that you can access the seals. If this tractor has had a LOT of 3-point use replace the bushings also, they should fit tight in the bore. The nylon ring that goes on top of the O' ring is tricky, be careful with it. If the shaft is wore where it contact the seals replace it also $$. When reinstalling the shaft be aware that it has to pass through a notch in the load contrl arm so do not use any violent motion when you feel it make contact about halfway through. once you are past this point the rest is easy.
G-MAN
09-18-2003 13:49:01
It will slide right out, but you'll have to beat on it, as they fit tight in the seals. Also replace the bushings and make sure they are properly installed. Take your time, because those things are fairly easy to screw up, and it's even less fun to replace them the second time. You might also consider replacing your transmission sump screen and filter while you have the oil drained.
