1939 B parts tractor?
M.Smith
09-18-2003 13:19:06
Just bought a B from my neighbor, nothing too pretty but complete minus the rear rims. There is no tag but he says it is a '39. It does have the cast iron guards over the brakes. Is this a good sign that it may be a '39?
Thanks,
Mike
John T
09-18-2003 13:30:24
 Re: 1939 B parts tractor? in reply to M.Smith, 09-18-2003 13:19:06
Dear Mr. Smith, Is it styled or unstyled???? 39 was the first year the B was styled, they added compression relief petcocks then and the bore went from 4 1/4 to 4 1/2. My 38 Unstyled Long Frame has the brake covers, but if Im not mistaken, I think some of the 39 styled had that also before they went to the non covered ones.
Take care n God Bless
John T
M.Smith
09-18-2003 13:35:27
 Re: Re: 1939 B parts tractor? in reply to John T, 09-18-2003 13:30:24
Yes it is styled with the petcocks.
John T
09-18-2003 14:15:02
 Re: Re: Re: 1939 B parts tractor? in reply to M.Smith, 09-18-2003 13:35:27
Well then we know its AT LEAST a 39 (thats about all I know for now however), but Im pretty sure Ive seen 39's at shows that had the covered brakes. My buddy Henry has a 39 with plain brakes and he threatens to swap his with mine. I used to think all styled had plain brakes, but then we saw some 39's at shows with the covered ones so I had to reconfigure my thoughts a bit. If it has the covered, I would still guess it to be a 39, cuz I dont recall having seen any 40 or later with them.
Hopefully a real B man can enlighten us all on the covered brake years. John T
Bob Collins
09-18-2003 15:20:42
 Re: Re: Re: Re: 1939 B parts tractor? in reply to John T, 09-18-2003 14:15:02
John, The covered brakes were used on unstyled Bs and styled B tractors 1939 and 1940 Up to serial number 96000. You can verify this in your parts catalog if you take the time to compare casting numbers because the picture is only of the later "plain" housing. If your buddy has a '39 B without the covers, someone has switched them. Shouldn't be a problem finding the correct ones,lots of them out there. Thanks for all your informational answers. Bob
M.Smith
09-18-2003 14:19:51
Thanks for your help. I can send you a picture later if you like. It is not beyond restoration at all. I have a totally disassembled '45 B that I can use to get the '39 up to snuff. The '39 is hand crank of course. The '45 was electric start with the long hood.
Mike
