Info about 4020
NWMO_Jim
09-18-2003 13:09:55
I just purchased a 69 4020D with a 148 loader at a retirement auction, so I'm a rookie when it comes to JD tractors.
My machine has a Hiniker 1300 cab, but there is no wiring that is connected. Does anyone have a wiring diagram to get this rewired? The cab is also missing the rear glass panel. The door latche on one side is non-functional. Is there an aftermarket supplier for these cab parts?
In my reading the archives on this forum, there is a lot of discussion about conversion of 24 to 12 volts, but my operators manual shows 2 six volt batteries in series. When did the switch to 12 volt standard occur?
Is there an aftermarket supplier of body parts for the 4020? The sheetmetal of the hood and side louvers is pretty beat up.
Thanks for your help.
G.E. Aronson
12-24-2004 20:24:16
 Re: Info about 4020 in reply to NWMO_Jim, 09-18-2003 13:09:55
Dear NWMO Jim.
I have a JD 4020 with a Hiniker Cab. Can you tell me what the cab is worth? I want to sell it.
Thanks for any info.
Jim B
09-19-2003 04:59:11
1969 is the yr. 3020's and 4020's came from factory as 12 volt system.Great change,less electrical problems,less fires I would guess.Jim B
Dan
09-18-2003 20:28:52
Not sure when they switched from 24 to 12 volts but if your manuel shows 2 6 volt batteries in series it must have been before your tractor was built. Does it have an alternator? A lot of these had either Hinson or Hiniker cabs. Keep the wind out but make them really noisy as the noise seems to echo down the hood. A very good tractor, would guess yours has the side console hydraulics? Rear windows generally fell victim to opening the window to see while hooking up to a 3 point rollover plow then with the window still open, lifting the plow into it. If 12 volt should be easy to wire from any source, just run through a circuit breaker or fuse pannel. It it is 24 volt you have to keep the system balanced and is a bit more difficult.
Mr. Green
09-18-2003 17:52:39
I have a 900 Hiniker on my 1966 4020. My John Deere dealer got a parts book from Hiniker for me. It also has the 1300 with it. They also got some parts for me. Some weather stripping, and window molding. I was from Hiniker. I got used door latchs from a 55 combine cab. That cab has a small door on the right side. So it has a right and left hand door latch. Their is one wire going from the tractor switch to the cab fuse block. Wires for the lights are in the back. They plug into the plug the tractor has. They had 12 or 24 volt blower motors. I'm told most were run on 12 even if the tractor is 24.
