Coolant question: What gives here, guys?
Loren
09-18-2003 11:08:12
A while back there was discussion about coolants. Some of our experts indicated that water will cool better than straight anti-freeze or a mixture. I just got back from a 600 mile (one way) trip (NC to IN) and contended with an over-heating vehicle the entire trip. When I had replaced enough of the coolant so it was running straight water, it was running consistently at 196�. However, with water I was experiencing the low boiling point, so I began putting anti-freeze back into it, even though much of it was going back on the ground. When I had it back to a mostly anti-freeze mixture, it was running consistently at 196�. Now I am having trouble rationalizing how 196� with water is cooler than 196� with anti-freeze so somebody is going to have to 'splain to me!
DON
09-19-2003 14:49:21
 Re: Coolant question: What gives here, guys? in reply to Loren, 09-18-2003 11:08:12
I SUPPOSE THAT YOU HAVE PRESSURE WASHED THE RADIATOR TO REMOVE THE BUGS??
Clooney
09-18-2003 15:19:11
Loren, that discussion about coolants was probably about a thermosiphon cooled tractor....On those systems the antifreeze mixture makes a bigger difference due to no waterpump & no system pressurization...
~On your particular observation all you proved is that your vehicle's engine was capable of maintaining a 196� running temperature, probably due to the thermostat in it. Water will cool a little better than a mix of 50/50 ethylene glycol/water but as you observed it boils at a lower point. Water will cool a lot better than [straight] antifreeze but also boils at a lower temperature. ~Your temperature gage was reading engine temperature not how may BTU's were removed at the radiator. Water is capable of picking up slightly more BTU's from the engine & transferring slightly more to the radiator fins. On a pressurized or non pressurized system the use of antifreeze will allow the engine to run a little hotter without boiling over. ~The thing that I don't understand is how your vehicle overheated at 196� as straight water boils at 212� at sea level & using antifreeze in a pressurized system pushes that to well over 230�F.....
~One thing to remember is once the water level drops, your water temperature gage reads engine metal temperature at the point the gage sender is attached not coolant temperature. Unless there is steam present, then it will read the steam temperature [if it's higher or lower than the metal temperature]...
Loren
09-18-2003 15:30:55
 Re: Re: Coolant question: What gives here, guys? in reply to Clooney , 09-18-2003 15:19:11
You don't understand how it could boil over at 196�? I guess that means you want to hear the rest of the story! 196� was the successful part of the trip. It hit 250� once and headed up that direction a couple of other times. Took it to the dealership (in Kokomo, John T) and they told me the water pump was leaking. Problem was they couldn't explain to me why there was no wetness on the pump. They wanted $500 to fix the problem (yes, I pay for the name!) and I wasn't convinced they WOULD fix it so I babied it on back to NC. Now I have to see if I can find something that convinces me it could be a real solution. I know for sure that coolant is getting away. The question is where. I sure hope the answer doesn't turn out to be head or head gasket.
John T
09-18-2003 15:03:42
Hey there Loren, If I knew you were gonna be up here in Indiana, I would have had the ol lady bake a cake or something lol. Anyway, other times I make comments on thermodynamic topics, being an electrical and not a mechanical or thermo engineer, guys tease and have fun climbing all over lol me but this is an all volunteer network of good ol boys just tryign to help out and get along anyway, so here goes.
Its true that water is more efficient at transferrign heat then anti freeze, but as you indicate, anti freze helps raise the boiling point (air bubbles transfer heat even worse). However, even if water or pure antifreeze were used, so long as youre not boiling over, a working thermostat should still control the temperature, and if its sticking or not opening properly etc., youre still gonna run at an identical hot temperature maybe????? ?? i.e. if the t stat is controllong the temp to be 196, it would still do so regardless of the coolant. If the t stat were removed, the temp would vary dependign upon the coolant used and would then run warmer (assuming no boil over) on anti freeze than water I think.
Good Luck n God Bless
Hopefully a mechanical or thermo engineer can enlighten us all.
John Y
Loren
09-18-2003 15:21:10
 Re: Re: Coolant question: What gives here, guys? in reply to John T, 09-18-2003 15:03:42
You could be right but my philosophy was a bit different. Seems to me that it must have a 190� thermostat, since it stays close to that temperature. It also seems to me that it would open at 190� and what happened above that would not be affected by the thermostat. If that was the case, it seems like there would have been a couple of degrees of visible difference between the operating temperatures with water vs. antifreeze.
Lee
09-18-2003 22:03:26
 Re: Re: Re: Coolant question: What gives here, guy in reply to Loren, 09-18-2003 15:21:10
Leaking water pump is highly suspect story for $500 bill - I applaude your instincts for driving away. $8 thermostat can cause these symptoms when it has spewed it's wax guts into the water system and is no longer a 190 degree thermostat or one that either opens fully or closes completely either. Temperature wanderings with such a thermostat can't be explained so why try?
Trouble is head gasket and worse cracked head also demonstrate your 'trip from h*ll' symptoms almost exactly. In worst cases though a bad thermostat won't cause antifreeze to drip from exhaust pipe and you won't find combustion gases bubbling merrily in the raditor. You didn't mention either of these more serious symptoms so my money is still on a bum thermostat.
gary
09-18-2003 11:25:04
I don't know what to tell you about the anti-freeze, but it sounds like you need a new thermostat or water pump.
