1530 Steering Leak
Scott
09-18-2003 05:43:46
I am getting a small amount of oil leaking out the top of the steering column on a 1975 JD1530 (German Built). Can the top seal be replaced with totally removing and disassembling the column/valve assy? Any tricks or things to look for?
Thanks
Earl
09-18-2003 10:00:00
 Re: 1530 Steering Leak in reply to Scott , 09-18-2003 05:43:46
Scott; I looked at the illustrated parts breakdown and it appears the steering wheel and the adjuster nut can be removed and the seal in the adjuster nut and/or the o-ring under the adjuster nut can be replaced without removing anything other than the above mentioned components. I have a related question/s about the steering. Have you noticed any up-down action on the steering wheel when you turn turn the wheel with the engine running and the tractor sitting still/neutral
Scott
09-18-2003 10:06:26
 Re: Re: 1530 Steering Leak in reply to Earl, 09-18-2003 10:00:00
Earl,
Thanks for the feedback. From the looks of the breakdown in my IT manual, it looks like the seal can be replaced. To answer your question, with the engine not running there is about 3/8 to 1/2" vertical movement when you turn the wheel. Don't know about when it's running. I will check tonight. My friends 2030 does the same thing. Is that normal? Is that what the adjuster nut is for?
Thanks again.
Earl
09-18-2003 12:22:47
 Re: Re: Re: 1530 Steering Leak in reply to Scott, 09-18-2003 10:06:26
Scott; FYI, you can go to the JD homepage, locate parts in the dropdown menu, and register to order parts online. The benefits of doing this are thus: You can access an illustrated parts breakdown, by model number, for the equipment that JD has parts for, you can get part numbers, find out the cost of the part and order parts for pickup, if you choose to order from JD. To answer your question about the steering wheel movement. I think that may be normal because I have had two German JD's; an 830 and a 2240 and both exhibited the same up and down steering wheel movement. You don't notice it during operation and it apparent does not affect function; however, it drives me crazy thinking the steering "may" have slop in it. The JD maintenance manual does not address this problem and I don't know if the adjuster nut can be used to eliminate all up and down motion. It looks like it could be used for that but, you may may just tighten the adjuster nut down to a specified torque and some up and down movement is normal.
david val
09-18-2003 15:14:57
 Re: Re: Re: Re: 1530 Steering Leak in reply to Earl, 09-18-2003 12:22:47
a- the up and down movement of the steering wheel and shaft is operating the steering valves. if you want to check free moovement you should check steering wheel radial free movement, that shouldn't be more then a few degrees.
b- the 'adjuster' actually holds the steering valves tight in the housing, it does not adjust the up down movement.
c- the shaft seal can be replaced on the spot with or without removing the adjuster, but leakage there usually indicates internal leakage in the steering assembly that creates pressure in the housing resulting in the seal leak. usually the culprits are the 'o' rings that seal the valves in the housing.
david
