Installing a flywheel on an 48 A
matt
09-18-2003 04:44:12
I just put on a used flywheel and I want to know if I should locktight all the nuts including the one on the crankshaft. Also is there any torque specs that I should use with this procedure.
Clooney
09-18-2003 09:05:19
 Re: Installing a flywheel on an 48 A in reply to matt, 09-18-2003 04:44:12
Matt, I wouldn't recommend Loc-Tite on those flywheel nuts. ~While I do use a lot of Loc-Tite on old tractor nuts & bolts, the flywheel isn't one on those places. Those nuts should be checked for being tight after a little run time & every year or so after that. Once you Loc-Tite those nuts you won't be able to tell if they are tight by putting a wrench on them. As for the nut torque, there is a torque value somewhere [I don't have it handy], I don't use a torque wrench on those nuts myself as I usually use a moly grease on the threads & that will change the torque required to tighten them. [I have a good feel for bolt tightness though, been tightening those bolts for many years]
~One thing I would suggest is that you replace those bolts with new or use grade 8 bolts & hardened washers with tall nuts. Those original bolts are usually stretched from someone over-tightening them & once stretched they won't retain their torque�.
