High Alt Pistons vs. LP Pistons (made of unobtaniu
Tyler-MO
09-17-2003 19:57:23
Hi again....
As the saga continues,
My search for those unobtanium LP pistons for my 520 continues, however I have been told be everyone...I mean everyone, that those pistons are going to be like winning the lottery.
Anyway, I have located a set of .045 oversize High Altitude (flat top) pistons. My big question is how much difference in compression is there between the stock LP and stock High Altitude Gas pistons. I was told by the man that has them that the stock LP compression is about 7.1:1 Those ratio numbers don't mean alot to me as I only know that stock LP 520's should have 200 psi compression at cranking speed. Does anyone know the compression produced by the high alt pistons?? And is the difference great enough to be detremential to the engine performace?? I am finally taking my block, head, crank, and pistons to the machine shop tomorrwo to find out for sure about how much wear there is in the bore....Then I will know enough to decide as what to do...hopefully. Thanks for any info???
Tom in Mo.
09-18-2003 18:26:57
 Re: High Alt Pistons vs. LP Pistons (made of unobt in reply to Tyler-MO, 09-17-2003 19:57:23
I wouldn't go with the high altitude pistons. It sounds like you are getting close to losing patience. Patience is your best friend. Especially when unsticking a stuck engine.
Try calling the tractor junkyards in Texas, Oklahoma, Arkansas, Florida Etc. and see if anyone has what you need. I don't have names or numbers of j-yards down south but I'm sure someone can help here.
I have heard propane can be as high as 130 octane. I can't be sure but this is what i've heard.
This is completely off the wall; but maybe you could find a diesel piston for a different tractor that could be shaved or modified to bring it within tolerable specs for your 520. Ring size and placement for the diesel should be more than satisfactory for a gas or LP.?
FRITZ
09-18-2003 10:33:41
TYLER KEEP IN MIND THAT PROPAIN IS 112 OCTANE.I REELY DONT THINK HIGH COMP PISTON ARE GOING TO HERT ANY THING.FRITZ GOOD LUCK
Tim Raska
09-18-2003 09:33:09
My son has a 520 LP that was overhauled and never ran (was to go under a cotton picker & the owner didn't pay for the O/H). He bought the tractor from the mechanic that had the lein for some hydraulic parts. I don't know if the pistons are STD or oversized or even new but if you are interested get with me & we can pull the head and see if they will work for you.
Later,
Tim Raska
979-571-7097 cell
979-478-6235 HM
Tyler-MO
09-18-2003 11:18:00
 Re: Re: High Alt Pistons vs. LP Pistons (made of u in reply to Tim Raska, 09-18-2003 09:33:09
Tim,
I tried calling you at the numbers provided but got no answer. Yes, I would be very interested...and hopefully they are .045 oversize. I think that the pistons will be stamped in the top of the piston. Mine were labeled 520 LPG and nothing else. I would imagine that the oversized would have .045??? But yes, if you can determine that they are good and not worn I would be interested. My number is 573-768-1758 L.M if no answer. Thanks
Tyler
ChuckW
09-18-2003 04:40:36
wanted to explain, that these were used in a gas engine....naturally if you have LP you need to use them. Would not recommend their use in gas. Now is did put a set of hi-altitude in a 620, they were dished and upped compression slightly, had no trouble out of that arrangement.
ChuckW
09-18-2003 04:37:38
Had a 520 with what was called hi-altitude but they were LP as they were flat top. Had a misserable experience, compression was 160#s and I could never get the carb calibrated. Found that this much compression did no good at all and went back to standard pistons, tractor ran much better, more power. The extra compression is no help unless you can turn more rpm, bigger valves, hotter ignition. High compression better served in an rpm engine. Would not recommend their use.
Ron
09-17-2003 20:05:47
According to my book, the Gas CR is 7:1 the LP CR is 8.75 :1
I'll bet that the "Hi Altitude" pistons are not near that high... From what I have found, for my 520 (I never did find any LP pistons for it) I think you might as well have a set custom made...
Tyler-MO
09-17-2003 20:08:19
 Re: Re: High Alt Pistons vs. LP Pistons (made of u in reply to Ron, 09-17-2003 20:05:47
What exactly did you have "custom" made? At least it sounds like someone else has a similar problem as myself. Can you refer me to someone that can make pistons? Thanks
Tyler-MO
