Good 2-Cylinder Mechanics!
David Lile
09-17-2003 19:36:16
Looking for a good qualified mechanic to overhaul my 44 B handcrank. It currently runs but smokes real bad. Would like to have it resleeved and new rings. Any good 2-cylinder mechanics in the Wichita Falls, Texas area?
F-I-T
09-17-2003 19:49:45
 Re: Good 2-Cylinder Mechanics! in reply to David Lile, 09-17-2003 19:36:16
David:
Why not try it yourself? A "B" makes a great first time overhaul project. Are you sure it needs "sleeved"? Boring is probably cheaper if there's room to bore, and there are lots of "B" pistons out there. A "B" fits in a garage nicely, and since it's a handstart, you don't have much to refurb other than ignition and carburetor if they even need attention.
A story....a friend of mine had a michine shop, and another friend wanted to overhaul his '41 "B". It had a bad babbit rod bearing, and my friend know that it would need bored, so he found pistons (he knew the bore diameter that it was from a previous repair), a good used set of babbit rods, and had a gasket set on hand. We tore it down starting on Saturday morning at 8 AM, and took the block and head to the machine shop by noon. Left there with a fresh block and valve job, and gave it a spin at 10 pm that night, and drank some beer while it warmed up. It's still running on that hurry up job today.
Give it a shot ! There's lots of help here !
Frank
Mike Horne
09-17-2003 19:47:30
Hello,We can take care of your needs,But we are in the Tipton Okla.area,but we can haul if you can't,Reference Noel Smith at Big State Grinding in Wichita Falls Tx
David Lile
09-19-2003 08:40:18
 Re: Re: Good 2-Cylinder Mechanics! in reply to Mike Horne, 09-17-2003 19:47:30
Mike Horne,
I have been working on my 44 B handcrank in my spare time for 11 months. Tractor had not been started in over 10 years when I bought it. I have sandblasted entire tractor, completely restorted radiator, carburetor, magneto, head with valve job and new push rod sleeves, steering wheel and gas tanks. I tied the small gas tank to steering column just so I could start tractor and drive it around.
I want to put engine back to the best mechanical condition as possible. I have a 1944 B parts tractor that was produced the same month as mine. What kind of cost am I looking at?
Mike H
09-20-2003 19:06:17
 Re: Re: Re: Good 2-Cylinder Mechanics! in reply to David Lile, 09-19-2003 08:40:18
I think Frank is right you have done everything else,there's not that much to it
