Green front hubs?
Bill R
09-17-2003 19:24:52
Did any tractors come from waterloo with the front hubs painted green? When restoring a 1949 john deere B in very original condition, the hubs were green and i found no evidence of yellow paint below that. Can't remember if that is in JR Hobbs styled letter series book or not, guess i'll have to read it again.
F-I-T
09-17-2003 19:40:09
 Re: Green front hubs? in reply to Bill R, 09-17-2003 19:24:52
Bill R:
I've seen several factory pictues of the painting process at Waterloo, and it shoed that they installed steel wheels on the early tractors for transport ing them around the shop and so that they could spray the green on everything. Later after the green was dry, the yellow wheels were installed, probably already with the yellow hub bolted to the rim. Then the bearings were snugged up, the cotter key put in the hole, and the bearing cap and three bolts tightend up.
I do not believe there were any green hubs on a new tractor built in Waterloo. As far as what you find as original, remember, the yellow wore off very fast if the tractor was run in high stubble. Also, someone might have stripped the paint off during a previous painting session. I know on any of the parts that I can fit in the electrolysis tank are devoid of original paint when I'm through, so someone centuries from now will be on this forum saying that Waterloo used gray epoxy primer !
Frank-in-Tallahassee
70D // 855 // VAC
Bill R
09-18-2003 10:35:43
 Re: Re: Green front hubs? in reply to F-I-T, 09-17-2003 19:40:09
thanks F-I-T, i not stating thats the way it was, but if its supposed to have yellow hubs thats the way i want it to be. thanks for the input, don't mean to steal an idea but i like how you put your tractor models under your name!
Bill R
B // A // GW // R Diesel
F-I-T
09-18-2003 12:33:12
 Re: Re: Re: Green front hubs? in reply to Bill R, 09-18-2003 10:35:43
Bill:
Imitation is the sincerest form of flattery !
You have some nice models!
Frank
