CLOONEY QUESTION
GERRY
09-17-2003 18:48:07
I AM JUST GETTING BACK WITH YOU ON THE JD-H GAS TANK REMOVAL QUESTION.
I HAD TROUBLE WITH THE TRACTOR NOT WANTING TO START AND FOUND IT WAS NOT GETTING FUEL. THE SEDIMENT BOWL WAS CLEAN SO I LOOKED INTO THE TANK.
WHAT I SEE IS A COATING LIKE PAINT COMMING OFF OF THE INSIDE OF THE TANK BLOCKING THE INLET. I DON'T WANT TO REMOVE THE TANK! HERE IS MY THOUGHT. DRAIN THE TANK REMOVE THE SEDIMENT BOWL LET IT GET GOOD AND DRY.
TAKE A DOWEL ROD PUT A COUPLE OF HOLES THROUGH I AND PUT NYLON STRING THROUGH THE HOLES AND TIE KNOTS NEXT TO THE DOWEL TO HOLD IT. CHUCK IT IN A DRILL BEATING THE INSIDE THE TANK AND GET MOST OF THE LOOSE COATING OFF AND SHOP VAC THE MATERIAL OUT. WHERE THE COATING HAS COME LOOSE THE TANK IS SHINEY.
ANY BETTER IDEAS
Orchard Boy
08-17-2004 14:23:14
 Re: CLOONEY QUESTION in reply to GERRY , 09-17-2003 18:48:07
I had the exact same problem!
I'm kind of new to working on tractors and couldn't get any useful advice on the problem. I came up with a solution that has kept me in business for several months now!
I took a piece of metal screen,(about three inches high) and rolled it just small enough to fit inside a piece of 1/2" pipe. I then folded the end of it over. I took a threaded coupler and a piece of 1/2" pipe (1 1/2" Long) and put the screen in it. I then put my contraption in between the tank and the inlet. It's worked perfect.
Clooney
09-18-2003 04:07:44
Gerry, listen to Frank. DON'T use a shop vac on that tank. There was a guy not too far from me that did that on his boat tank & blew up his boat, garage & himself.
~As Frank said that tank liner was probably put in there for a reason & if you remove it you will probably have a bunch of pin holes show up in the bottom of the tank.
~You really should remove that tank & clean it out then, etch it with Phosphoric acid, then re-coat it with something like Kreem���
F-I-T
09-17-2003 20:09:37
Gerry:
I know you were looking for CLooney, but I wanted to tell you as quicl as I could that I'd think twice before I used a shop vac to draw air out of a tank that has recenty seen fuel. Those shop vac motors have exposed brushes, and you stand a heckuva chance of really lighting things up from the sparking brushes!
That coating is probably a poorly installed gas tank liner from a previous repair. Remember, it was put in there for a reason, so it sounds like that tank was a leaker before. You are not going to be happy until you remove that tank, clean it throughly, and fix any leaks properly.
If you take it off, I have some ideas on tank cleaning that have worked very well for me in the past.
My $.02
Frank
