Mike: No you weren't ! You were being abrupt and snide, intimating that the guy was using up valuable thread space and bandwidth asking a question on where to find obsolete gaskets. You said: "Buy some gasket marerial from your local auto parts store and cut one out. I could have had it done in the time I spent here. " ...like he was taking up YOUR valuable time and board space. He knows he can cut out a gasket. We all have at one time or another. He might have more than one obsolete gasket to find, or like to pass a source on to a friend. Then you said: "You can search the ends of the earth if you want to for an NOS gasket good chance it will be dried up and won't fit. Most gaskets are very easy to make and you get fresh material. I always buy mine when readily available but can make them if needed. " This was an excellent, appropriate, lucid comment that would have gone far to aid this fellow in his quest for gaskets. You should have put it that way first, but instead you chose to belch that YOU could have made a gasket in the time you spent here. Big important dude, you are..... And finally the info that I could not go on without knowing..... "Just trying to give someone another option that you must not know anything about. " You don't know what I don't know. But we all know a lot more about what YOU don't know. If you want to be short with people on this board, this is what you get. You tried to be cute and some one called you on it, now all of a sudden you were just trying to give the guy an option. If you want cute, I can get downright adorable..... Excuse me while I brush my tooth.
