Dist. on an A John Deere
Gene
09-16-2003 18:42:11
What all do I need to convert from a mag to a distributor on my 1947 A? I Can't get the mag to run the way it should and it's been rebuilt. Will an automotive type coil be ok to use? How do I keep it in time when mag comes off? Thank you in advance, Gene.
CTex
09-18-2003 07:16:38
 Re: Dist. on an A John Deere in reply to Gene, 09-16-2003 18:42:11
If interested I have converted a mag to a coil ignition several times. It is very easy and cost no more then a coil and a little wiring. You don't get it out of time and works like a champ.
Clooney
09-17-2003 07:41:48
Gene, that depends on the type of distributor you have access to. The Wico XD distributor will work & is probably closer to production on your A. The only problem is that Wico distributor is probably not the best choice as it isn't much better than a mag.
~If you are going to all the trouble of installing a distributor you really should try to find a Delco [round cap] distributor.
~To install a Delco distributor you will obviously need the distributor, a 12 volt INTERNALLY RESISTED ignition coil [auto parts coil is fine] , a coil mounting bracket, a dash mounted on off switch [or an original Deere "A" distributor tractor ignition switch], & some 14 gage wire & some wire terminals.
~Hooking the power up is a no brainer as all you have to do in run power from the NON-battery side of the ammeter to the dash on/off switch, then run a wire from the on/off switch�s [switched terminal] to the coil�s non-distributor terminal. That terminal would be the positive terminal on an auto parts coil or the negative terminal on an original Deere coil. Then run a short wire from the coil�s other terminal to the small post on the side of the distributor
~Now to install the distributor�to do it properly just remove the L/H spark plug & turn the engine until there is compression of the L/H cylinder, then line up the flywheel dot with the flywheel cover�s dash mark on the bottom of the cover�s center hole� Or line the flywheel�s L/H impulse mark up with the case mark. Then install the distributor with the spark rotor pointing to the front [or top] plug wire tower. OR, you can just install the distributor [it will only go in two ways] & install the wires, if it won�t start that way just reverse the plug wires & it will work. [that distributor is a one revolution per every flywheel revolution so it will work either way by just reversing the plug wires]
~Once the distributor is installed & the proper plug wire runs to the correct spark plug just pull the L/H spark plug, then re-attach it to the plug wire, then lay it on the engine block, then turn the engine in the starting direction until you feel compression on the L/H [flywheel side] plug hole, then turn the flywheel a little farther until the flywheel dot lines up with the notch on the bottom of the flywheel cover�s center hole. OR, until the L/H impulse writing on the flywheel lines up with the case mark [at 3 o�clock on the case behind the flywheel & even in height with the center of the crankshaft]. Now loosen & turn the top of the distributor all the way to the front as far as it will go, then turn the ignition switch on, then slowly turn the top of the distributor to the rear, when the L/H plug that�s laying on the block sparks it is timed correctly so just tighten the distributor down there.. That�s it, as easy as that� ~I have my doubts that a distributor will make much difference on how your tractor runs if you have a stock tractor. A good mag should run that tractor just fine. It�s very possible you have other problems like a worn R/H governor case bore or bearing that�s causing your problem & that will be the same with either a mag or distributor. Or you could have a carburetor problem or other engine related problem�
[email protected]
John T
09-16-2003 21:51:28
Gene, if you convert to a Delco Distributor battery powered ignition, you will need the distributor, a 12 volt coil and its mounting bracket, some sort of an ignition switch to turn the ignition on or off which feeds the coils high (not to distributor) side, and, of course, a battery and charging system. Its good to start with a fresh set of proper gapped points and condensor in the distributor.
1) Run a 14 gauge wire off the ammeters load (non battery) side (same side that feeds any light switch and the Voltage Regulator's BAT terminal or cut out relay) to the input of an ignition switch. Source of 12 v power.
2) The output of the switch is wired to the coils high (not to distributor) side via a 14 gauge wire.
3) The coils low (not to switch) side is wired to the lil side terminal post on the distributor with a 14 gauge wire.
4) Timing is somewwhat similar to a mag, when the Left Hand Impulse timing mark on the flywheel is in the 3 o clock position in line with the flat mark on the tractor,,,,,and the left pistom is at TDC on its compression power stroke,,,,, ,,, the points should be near open (high cam) to fire the left hand plug (rotor tip is then in line with caps pickup tower to the left plug),,,,, , then 180 later, the right hand cylinder is at its power stroke TDC and the points again near open on high cam to fire the right cylinder and the rotor tip is in line with the caps right side plug tower pickup.
You can install the distributor and have it max retarded (max CW rotation) then bring the flywheel up where the left hand cylinder is at TDC on its compression power stroke (LH Impulse at 3 o clock) and then slowlyyyyy y rotate the distributor CCW to advance just until the left plug fires (similar to when a mag snaps) and set it there. The distributor has to be installed so the left cylinder fires (points open) on its TDC Power Stroke, and then the right one on its 180 degrees later. If its not in correct, you cant reverse the wires to make her run like on the Wico C or XH mag remember.
An auto type internal ballasted 12 volt coil will work okay. I say ballasted, because its important for the life of the points that their current is limited to around 4 amps. Therefore at 12 volts, you need a total of around 3 ohms resistance in the points circuit which a 12 volt coil using an internal ballast should have. BE SURE THE DC RESISTANCE OF THE COILS PRIMARY (between lil + and - terminals) IS NEAR 3 OHMS. Some say on the case 12 volts internal ballast. You do NOT want one labeled for use with an external ballast unless you add an external series ballast resistor in the circuit.
On internal ballsted 12 volt late automotive type coils, I wire the coils - to the distributor
and its + gets power from the ignition switch.
Its late and Im going to bed but this should give you an idea.
Post back or e mail [email protected] or call (812) 824-4608 with any questions. Let us know how you make out.
Good Luck and God Bless
John T
Gene
09-17-2003 19:43:08
 Re: Re: Dist. on an A John Deere in reply to John T, 09-16-2003 21:51:28
Clooney and John T. Thank you so much for the detailed info for my dist. conversion and for taking time to share your knowledge with others!
I'm new to JD tractors but I'm learning. Gene
