45 A making oil
RickinMo
09-16-2003 16:47:55
My A has started making oil, the oil turns whiteish gray and the crankcase is over full and it has started to smoke. my A is a hand crank model and it likes to be choked until gas comes out the petcocks then it will start. I thought I was maybe flooding it and contaminating the oil with gas but the oil I drained out of the dripper doesn't really smell like gas. It doesn't seem to be getting rid of water but I have a feeling it is and is a head gasket, head or cyl. can someone confirm or revise my diagnosis for me
Thanks Rick
Clooney
09-16-2003 19:18:33
 Re: 45 A making oil in reply to RickinMo, 09-16-2003 16:47:55
Rick, before you go looking for trouble in the engine be sure that water isn't getting into the engine from leakage around the clutch fork shaft, or through the exhaust, or even the air intake. [a very common problem on the 2- cylinder Deere]
~Pull the air cleaner oil cup & look for water, if you have water in there suspect it has also entered the muffler or clutch shaft area.
~If you leave the tractor outside that rain water in the engine would be at the top of my list, if you always park it inside then your head gasket or pushrod tube theory would be a good place to start..
~You might want to drain the oil then change the filter & add new oil. It will take a while of running that tractor under load & getting it working hot to purge the engine of all the water that's hidden in all those hard to drain places..Be sure to drain the 1st reduction cover as that is probably water filled also..
~If you have antifreeze in the radiator that will show up in the oil, if the water in the engine is just water it probably isn't from the cooling system...
[email protected]
Will P
09-16-2003 20:45:32
 Re: Re: 45 A making oil in reply to Clooney , 09-16-2003 19:18:33
Clooney, correct me if I am wrong. But the early styled A does not have push-rod tubes. It has been a while since I looked at my 43A head. I don't remember a drain in the reduction gear cover either. Not until the late styled. But I put one on my 43B when I had it apart. Best thing I could have done.
Will P
Clooney
09-17-2003 02:34:12
 Re: Re: Re: 45 A making oil in reply to Will P, 09-16-2003 20:45:32
Will, you are correct, I should have looked. The "A" used outer push rod tubes through 1940.
~On the first reduction cover....some have drains & others don't, if they don't have a factory drain you have to drill them on the lower rear bottom & then tap the hole & install a small machine screw for a plug.
John T
09-16-2003 18:04:35
Good Evening Rick, Im afraid I have to agree with your water in the oil diagnosis. Generally speaking, a white or gray or milky color present in the oil is often water and/or coolant. Gas in the oil remains a black oil color and it can be very thin and smell gassy.
It could be getting in past the head gasket (maybe try a re torque) or a crack as you mentioned in the head or block somewhere (hope not), but its also possible the push rod tubes are leaking and I have seen more than one A that leaked there. If you remove the valve cover, you may be able to observe water running out the tubes????? ??
Anyway, thats been my observations. If its water and you cant locate the source of the leak and have to pull the head, I would have it checked (maybe plane the heads manifold surface and the manifold itself if needed), replace the manifold studs if needed, replace the push rod tubes if needed (place them in freezer overnite before installing them helps), and with a new gasket you will hopefully have all the darn leaks plugged.
Good Luck and God Bless
John T Nordhoff
