Hi Wayne, When I learned that a neighbor could get me the gauge in a couple of days, I just waited for the gauge and I thought I would save squirting the oil everywhere. Yes I did try it @ WOT, but not much on the gauge. When I removed the gauge to put the plug back in, the oil was foamy, while the first test it was still clear and clean...this leads me to believe that [while sitting in the tractor], the left side [where the pressure line comes in] has some minimal pressure, enough to ease the oil out of the line, but not enough to really move the dial on the gauge. The return line looks intact everywhere and all the couplings seem tight. How can you find pinholes if that's the case? The 10W oil has been filled to the spill-over valve, so I have heard that the pump should prime if the oil is full. Wayne, you mentioned the gear attached to the camshaft may be broken, is that a good chance or a longshot?..I hope a longshot. I guess I will find this one out when I pull the pump. Anything else, just let me know and I will get on to it. Thanks again Wayne, tom
