2555 electrical problems
NortonWNY
01-19-2004 19:05:59
My friend has a 2555 with cab and the alternator light stays on all the time.I cleaned the battery terminals, checked and tightened the belt.had anew alternator put on it in 2002.Does anyone have some pointers? Thank You...Nort
John Scroggins
05-12-2004 20:05:22
 Re: 2555 electrical problems in reply to NortonWNY, 01-19-2004 19:05:59
Check the relay on the board under the dash. There should be two relays. One for starting and the other for the insturments. The one you are looking for has diode in it.Without the proper relay or if the diode is out the alternator won't charge.
Far North
01-20-2004 08:12:41
If the alternator is like the one on my 2750, if the voltage from terminal B+ to ground is around 14V with the tractor running, the alternator is working.
Ty
01-19-2004 20:30:33
I would take it off and go have it checked out. Around here they usually do it for free but you never know. It would be a start?
