530 parts needed
Tim
09-16-2003 08:41:52
Needing a gas tank, brake shoes (JD too pricey), and seat parts (pins, bushings and torsion springs) for a 530 gas.
Thanks in advance,
Tim Raska
Tim Raska
09-18-2003 09:47:33
 Re: 530 parts needed in reply to Tim, 09-16-2003 08:41:52
Thanks for the input. I found a local older mechanic that said he could fix the tank and then I'll go & put the liner with a kit that I can get from auto paint store. I found some used brake linings & will check them out today. If that don't work out I'll hit the clutch rebuilder in Houston.
Later,
Tim
MIKE HANLEY
09-16-2003 22:28:14
There was a supplier for the rubber seats springs, but they were made overseas and they were taken off the market because they failed in short order. I only one that I know of at this time that redo's your springs is Minn-Kota Repair Inc. in Ortonville Minn. They have a web site. Remove your rubbers with the mountings and send them in and they mount new good rubber on your mountings. $110 for the two. Bushings were $40. They as well as JD have the bushings. But Jd no longer sells the rubbers. We just had them redo our 630 seat rubbers and I'm going to send in both the 730D's seats. I have a 60 year old back that needs all the help it can get.
When I talked to them on the phone they told me that one copaney made all the seats for JD FORD IH Oliver and others. The rubbers were all the same for all the brands. What was differant was the mountings from tractor maker to tractor maker. The corker is the shock. It's made by GABRIEL as a contract item made for and sold only to JD. cost $82 bucks. Someome else says that there is a scock made by MURHPY that will work. I haven't chech this out yet as it would have to have the same "coution bounch" as the JD shock to work the seat right. Not just fit and look O.K. A show tractor is one thing, but if your in the saddle all day, every day you want it to work right. Hardest part to do when redoing a seat is getting the plate smooth where the decal goes under the rubbers to show how to ajust the seat. Seen show tractors with dings and humps under the decal. Yes mine too! Next one I do, I may epoxy a thin plate over the old one. $230 bucks to redo a seat with you labor to remov and rinstall. Plus the seats coutions. And the good seats with the springs as from the factory from the THE SEATMAN in South Dakota,,, Add $85 bucks. $315 bucks for a seat or how much for pills and trips to the DOC? Like the guys that wouldn't pay $110 for a factory baffeled ovel muffler from JOHN DEERE but will pay out several hundard bucks for a hearing aid in a couple of years. Will that guy that saids a certion model is worth only so many bucks please step forward along with the guy that with the guy that wants to know what's it's worth.
MIKE HANLEY
09-16-2003 22:41:16
 Re: Re: 530 parts needed in reply to MIKE HANLEY, 09-16-2003 22:28:14
PS: how bad is your gas tank? JB WELD and then that red liquid gas tank liner will go a long way in saving a gas tank. Neverv had to do a tractor gas tank, but did a 1946 WILLIS CJ-2A JEEP's gas tank several years ago and it's holding well. Wouldn't go welding on the tank unless you are an expert and your life insurance is paid up.
Jon
09-16-2003 13:14:18
Try a local clutch and brake shop! We took our worn out originals to a local clutch & brake shop. They re-lined them at about 1/3 of the JD parts price.
Good Luck.
