JD 2640 Diesel
Gary
09-16-2003 08:37:38
Yesterday I was bush hogging with my 2640 when it started losing power. When I tried to throttle up the engine emitted some white smoke. It seems to be missing on at least one cylinder. There is also some minor fuel leakage on top of the injection pump. I have had the tractor about two months and it was serviced by the dealer before I bought it (Oil change, new air cleaner, etc.)
Any ideas what I am dealing with?
Spoker
09-16-2003 14:28:34
 Re: JD 2640 Diesel in reply to Gary, 09-16-2003 08:37:38
Sound like the return line is stopped up. remove the return line intop of the injection pump. It is a small line 1/4 inch line. Then remove the fitting, There should be a glass ball check valve inside the fitting that is not working. Replace the fitting with a new one and reinstall the line. We use to in the past break the glass ball out and return the tractor to service until we purchased a replacement check valve. Replace the fitting as soon as possible if you break the glass ball out of it.
Gary
09-19-2003 05:55:57
 Re: Re: JD 2640 Diesel in reply to Spoker, 09-16-2003 14:28:34
Spoker,
Thanks for the tip. I contacted a local diesel engine repair shop and he said the same thing. Iguess the new ones are made of neoprene or vynil though. Said that something inside the injection pump had deteriorated and I could replace the piece,(He has them in stock) but the new one would just clog up too. He said to go ahead and remove the check ball and spring and there would be some stuff that looks like coffee grounds in them, He was right. Runs fine now, but he said I would need to rebuild the injection pump one of these days as it is now metal on metal where the neoprene was and is causing wear now. Thanks again!
